Product
OtterBox Lightning Connector to USB Cable - 3m
Quicklinx: D31BWS00 Mfr#: 78-51153
Charge up your iPhone or iPad with this charging cable made for Apple devices. The OtterBox Lightning Connector to USB Cable is made rugged for long-term durability. It features an extended strain relief at that notorious weak spot where the cable and connector attach. It's one-meter long, charges at 2.4 AMPs and its braided nylon avoids tangling itself into knots. Upgrade your charging experience with the cable that's made to last.
OtterBox Lightning cable - Lightning / USB 2.0 - 3 m
Cable
Length
3 m
Connector
USB - male
Connector (Second End)
Lightning - male
Sync and charge, tangle-free
Apple 12.9-inch iPad Pro (1st generation, 2nd generation); 9.7-inch iPad (5th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, SE; iPod nano (7G); iPod touch (5G, 6G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB 2.0
Length
3 m
Connector
4 pin USB Type A - male
Apple Lightning - male
90.7 g
Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, SE , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
