No outlet? No problem. The LIFEACTÍV Power Pack delivers a burst of energy when your device hits the wall. Whether you're two days deep on a backpacking trek or ten hours away from landing in Bali, its fast-charging core keeps your batteries gassed up and raring to go. And since it's waterproof, drop-proof, dirt-proof and snow-proof, you can pack this portable charger on any mission.
Raw power
With a powerful power bank at its core, your LIFEACTÍV Power Pack keeps phones, tablets and other devices running strong. -
Smart circuitry
Auto-stop charge technology saves life for later, and rapid recharge speeds up the time it takes to fill your Power Pack battery charger. -
Shine a light
A brilliant, built-in LED turns your battery charger into a flashlight - perfect for lighting up the dimmest conditions.
- Lifeproof LIFEACTÍV POWER PACK power bank - USB
- Product Type
- Power bank
- 17.08 cm x 7.51 cm x 1.774 cm
- 250 g
- Black
- Output Connector Type
- USB
- Battery
- 10000 mAh
- Product Type
- Power bank
- 17.08 cm
- 7.51 cm
- 1.774 cm
- 250 g
- Enclosure Colour
- Black
- Input Connectors Qty
- 1
- Output connectors
- 4 pin USB Type A
- Capacity
- 10000 mAh
