OtterBox LifeProof FRE for Samsung Galaxy S7 - White
Quicklinx: D1JYWS00 Mfr#: 77-53379
Live outside the limits and document your deeds with Fre. Fully sealed with a built-in screen cover, this case gives you the freedom to push extremes.
  • Fre
  • Form-fitting design
    Fre is made to complement your phone's clean lines, adding mere millimeters and grams to its size and weight.
  • Zero compromise
    Customized for a flawless fit, LifeProof cases keep every button, camera and feature open for action.
LifeProof Fre - protective waterproof case for mobile phone
Protective waterproof case for mobile phone
8.255 cm x 1.473 cm x 15.672 cm
42.4 g
Avalanche white
Underwater Depth
Up to 2 m
1-year warranty
Samsung Galaxy S7
8.255 cm
1.473 cm
15.672 cm
42.4 g
Underwater Use
Avalanche white
Carrying Case
Recommended Use
For mobile phone
Protection
Waterproof, shockproof, dirt-resistant, vibration-proof, drop-proof, snowproof
Underwater Depth
Up to 2 m
Headphones adapter, microfibre cleaning cloth
IEC 60529 IP68, MIL-STD 810G 516.6
1 year
Samsung Galaxy S7
