With this rugged waterproof case, you're free to take your tech into every soggy, muddy, hard-knock adventure.
Reliable protection
With its built-in screen cover, your case keeps your display in pristine condition. -
Compact design
Incredibly compact yet impressively tough, this case is built sleek to complement the clean lines of your device. -
Full-featured function
Every port, control and feature remains in play, so your smartphone works just the way you want it. -
Explore the extraordinary
With this case, you're free to live in the moment with no hesitation - even when life takes you on watery, filthy and rocky adventures.
- LifeProof Fre - protective waterproof case for mobile phone
- Product Type
- Protective waterproof case for mobile phone
- 7.9 cm x 1.2 cm x 15 cm
- 35 g
- Material
- Silicone, polycarbonate, polypropylene, synthetic rubber
- Grind grey
- Underwater Depth
- Up to 2 m
- 1-year warranty
- 7.9 cm
- 1.2 cm
- 15 cm
- 35 g
- Underwater Use
- Material
- Grind grey
Carrying Case
- Recommended Use
- For mobile phone
- Protection
- Shockproof, dust-resistant, dirt-resistant, drop-proof, snowproof
- Underwater Depth
- Up to 2 m
- 1 year
