OtterBox Defender Series for Apple iPhone 5s/SE - Black/Black
Quicklinx: CK00WS00 Mfr#: 77-33322
The multi-layered Defender Series iPhone 5/5S case guards against drops, shocks and dust while maintaining seamless usability. The high-impact polycarbonate shell fully covers the iPhone 5/5S while the integrated screen protector guards against scratches and smudges. Built-in memory foam cushions the device inside the case while the outer slipcover absorbs impact from drops and shocks. The included holster clips to nearly anything and doubles as a kickstand for hands-free use. Get protection that inspires confidence with the Defender Series iPhone 5/5S case from OtterBox.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
  • Two-piece internal shell snaps around the iPhone while internal foam padding provides cushioning
  • Integrated screen protector guards against scratches and smudges without affecting the sensitivity of the touch screen
  • Outer synthetic rubber slipcover wraps around the inner shell and absorbs impact from drops and bumps
  • Included holster swivels in any direction, clips easily to belts and bags and locks in place to act as a kickstand
OtterBox Defender Series Apple iPhone 5s - protective cover for mobile phone
Protective cover for mobile phone
Material
High-impact polycarbonate, synthetic rubber
Black/black
1-year warranty
Apple iPhone 5, 5s, SE
Material
Black/black
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Dust-resistant, scratch-resistant, drop-proof
Holster
Foam padding, rugged, port covers, built-in screen protector
1 year
