OtterBox Defender Series for Apple iPad Air Pro 9.7" - Black
Quicklinx: CWF4WS00 Mfr#: 77-53675
£40.33 ex VAT
£48.39 inc VAT
Put three layers of rugged protection between your tablet and the world. This case is made to protect from heavy use, drops and tumbles.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
  • Multi-layer iPad Pro case for maximum protection
  • Screen protector guards touchscreen against scratches and scrapes
  • Port plugs lock out dust and dirt
  • Included shield stand comes equipped with a convenient slot for your Apple Pencil
  • Apple Pencil and iPad not included – case only
  • Does not work with Apple Smart Keyboard or Apple Smart Cover
  • Rugged defense
    Defends your device from impact with shock-absorbing layers.
  • Display protection
    Built-in screen protector keeps out dust.
  • 360° coverage
    Three layers surround your tablet with ultimate protection.
OtterBox Defender Series - protective case for tablet
Protective case for tablet
Screen Size Compatibility
9.7"
Material
Polyurethane, polycarbonate, foam, synthetic rubber
Rugged
Material
Carrying Case
Protective case
Recommended Use
For tablet
9.7"
Protection
Shockproof, dust-resistant, scratch-resistant, dirt-resistant, impact protection, drop-proof
Shield stand
