Defender Series rugged case covers your entire tablet with three layers of rugged protection. And, it includes a shield stand for added screen protection and hands-free use everywhere.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Triple-layer defense: inner shell, outer slipcover and touchscreen protector
- Screen protection: built in to keep your brilliant display flawless
- Port covers: stop dirt, dust and lint from getting into jacks and ports
- Shield stand: added touchscreen protection
- iPad not included
- Does not work with Apple Smart Keyboard or Apple Smart Cover
- OtterBox Defender Series - case for tablet
- Product Type
- Case for tablet
- Material
- Polyester, polycarbonate, synthetic rubber
- Black
- Limited lifetime warranty
- Designed For
- Apple 9.7-inch iPad (5th generation)
- Rugged
- Material
- Black
Carrying Case
- Case
- Recommended Use
- For tablet
- Protection
- Dust-resistant, scratch-resistant, dirt-resistant, drop-proof
- Included Accessories
- Stand, clear screen protector, port cover
- Lifetime
- Designed For
