OtterBox Commuter iPhone 15 Pro Max - Black
Quicklinx: HFMRWS00 Mfr#: 77-92590
Product Range: OtterBox Commuter Series
£13.76 ex VAT
£16.51 inc VAT
  • Compatible with iPhone 15 Pro MAX (Only)
  • DROP+ 3X as many drops as military standard (MIL -STD-810G 516.6) and is wireless charging compatible (no magnets in case)
  • Dual-layer thin phone case is made with 35% recycled plastic and features a rigid outer shell to protect against everyday scrapes and scratches while an internal rubber cover absorbs impact
  • Slim profile is designed to slip easily in and out of pockets, with textured sides for a secure grip
  • Eco-friendly choice
    With 35% of its composition made from recycled plastic, this case not only protects your phone but also contributes to a healthier planet.
  • Robust protection
    Crafted from durable polycarbonate and synthetic rubber, this case offers comprehensive protection against bumps, drops, scrapes, and scratches.
  • Wireless convenience
    Designed to support Qi wireless charging standards and compatible with MagSafe, ensuring your device charges efficiently without removing the case.
  • Pocket-friendly design
    The slim, streamlined design makes it easy to slide your phone into your pocket, while port covers keep dust and debris out.
  • Comprehensive coverage
    This protective cover encompasses every edge of your cell phone, providing all-around security without compromising on style or functionality.
OtterBox Commuter Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
8.43 cm x 1.51 cm x 16.63 cm
Material
Polycarbonate, synthetic rubber
Product Recycled Content
35 % - made of recycled plastic
Apple iPhone 15 Pro Max
8.43 cm
1.51 cm
16.63 cm
Package Details
Pro pack
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Scratch protection, bump protection, drop+ protection, scrape protection
Wireless Charging Standards
Qi
Cover Type
Back cover
Wireless charging support, port covers, pocket-friendly design
MagSafe Compatibility
Brand: OtterBox
