Keep your phone like new with lightweight, virtually invisible scratch and bump resistance. Clearly Protected Case, the ultra-thin case from OtterBox wraps your phone with a precision fit.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Transparent case: clear layer shows off your phone’s sleek design
- Ultra-thin: lightweight, virtually invisible case
- UV-resistant: transparent material won’t yellow or tarnish over time
- Precision fit: one-piece design wraps around your phone for a tight fit
- Screen bumper: raised, beveled edge buffers touchscreen
Clear case
Clear layer shows off your phone's sleek design. -
Ultra-slim profile
Lightweight, virtually invisible case complements the sleek, lean lines of your phone. -
Scratch protection
Helps preserve your phone's pristine condition while you're out and about.
- OtterBox Clearly Protected Case - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Thermoplastic polyurethane (TPU)
- Clear
- 2-year warranty
- Designed For
- Samsung Galaxy A3 (2017)
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop-proof
- Cover Type
- Back cover
- 2 years
- Designed For
