Fast Charge Wall Chargers are engineered rugged and built to outlast. This 45 W wall charger is powered by GaN technology, giving you higher efficiency by generating less heat and a form factor that is smaller than ever - all while providing maximum power. Like all OtterBox Wall Chargers, this charger is drop tested and wrapped in a tough exterior for years of use. Thoughtfully designed with good mobile expertise and proven quality that is uniquely durable, these tough wall chargers are designed to work flawlessly together with OtterBox cases, screen and power accessories.
Efficient charging
Equipped with GaN Technology, this wall charger offers efficient power delivery and less heat generation, ensuring your devices charge quickly and safely. -
Versatile connectivity
Featuring a 24-pin USB-C output connector, this power adapter provides wide compatibility with various devices, making it a versatile charging solution for all your USB-C powered gadgets.
- OtterBox power adapter - 24 pin USB-C - 45 Watt
- Product Type
- Power adapter
- Localisation
- United Kingdom
- Output Connector Type
- 24 pin USB-C
- Power Provided
- 45 Watt
- Limited lifetime warranty
- Product Type
- Power adapter
- Localisation
- United Kingdom
- Output connectors
- 24 pin USB-C
- Power Provided
- 45 Watt
- GaN Technology
- Limited warranty - lifetime
