The Optoma X600 will make your presentations shine with its powerful 6000 lumens bright output and stunning 10,000:1 contrast ratio. It delivers amazingly bright XGA resolution presentations with vibrant colors and sharp, clear text, graphics and video. Easily provides the brightness level necessary for use in medium/large rooms with ambient light - including meeting rooms, classrooms, and lecture halls.
The Optoma X600 features an impressive array of connectivity options and includes, Crestron RoomView for over the network control and management of up to 250 projectors. It is perfect for large scale enterprise installations in business and educational environments.
- Optoma X600 - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DMD Chip
- Brightness
- 6000 lumens
- Contrast Ratio
- 10000:1
- Resolution
- 1024 x 758
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
- Video Input
- (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 380 Watt
- 32.6 cm x 25.9 cm x 10.9 cm
- 3.7 kg
- 2 years warranty
- DLP projector
- 3D Capable
Projector
- Microdisplay
- DMD Chip
- Brightness
- 6000 lumens
- Contrast Ratio
- 10000:1
- Image Size
- 59 cm - 762 cm
- Projection Distance
- 1 m - 12 m
- Throw Ratio
- 1.8 - 2.1:1
- Uniformity
- 85 %
- Resolution
- XGA - 1024 x 758 (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 144 Hz x 90 kHz
- Bulb life cycle
- Side-by-Side, Crestron RoomView
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.6-2.81
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -15 / +15
Video Input
- TV System
- NTSC, SECAM, PAL
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Output Power / Channel
- 3 Watt
- 1 x DisplayPort - 20 pin DisplayPort , 2 x HDMI - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x 3D Sync in/out - 3 PIN mini-DIN , 1 x USB - 4 pin USB Type B
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Mounting Kit
- Optional
- Security Features
- Security lock slot (cable lock sold separately), security bar, keypad lock
- Security Slot Type
- Kensington security slot
- Nominal Voltage
- 380 Watt
- Power Consumption Stand by
- 1 Watt
- 32.6 cm
- 25.9 cm
- 10.9 cm
- 3.7 kg
- Limited warranty - 2 years , Limited warranty - lamp - 1 year
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission
- 28 dB
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.87 |
C2G HDMI to DisplayPort Adapter Converter | In Stock | £37.46 |
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £22.65 |
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £24.72 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £8.17 |
C2G 10m DisplayPort Cable with Latches M/M – Black | In Stock | £23.32 |
C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black | In Stock | £16.20 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £20.75 |
C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black | In Stock | £15.89 |
