Optoma X600 XGA DLP 6000 Lumens Projector
Quicklinx: 96RMWS00 Mfr#: E1P1D0N1E031
Brightness: 6000ANSI lumens
Portability: Non-portable
£949.62 ex VAT
£1,139.54 inc VAT
The Optoma X600 will make your presentations shine with its powerful 6000 lumens bright output and stunning 10,000:1 contrast ratio. It delivers amazingly bright XGA resolution presentations with vibrant colors and sharp, clear text, graphics and video. Easily provides the brightness level necessary for use in medium/large rooms with ambient light - including meeting rooms, classrooms, and lecture halls.
The Optoma X600 features an impressive array of connectivity options and includes, Crestron RoomView for over the network control and management of up to 250 projectors. It is perfect for large scale enterprise installations in business and educational environments.
Optoma X600 - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DMD Chip
Brightness
6000 lumens
Contrast Ratio
10000:1
Resolution
1024 x 758
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
Video Input
(NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i
Speakers
Speaker(s) - integrated
380 Watt
32.6 cm x 25.9 cm x 10.9 cm
3.7 kg
DLP projector
3D Capable
Projector
Microdisplay
DMD Chip
Brightness
6000 lumens
Contrast Ratio
10000:1
Image Size
59 cm - 762 cm
Projection Distance
1 m - 12 m
Throw Ratio
1.8 - 2.1:1
Uniformity
85 %
Resolution
XGA - 1024 x 758 (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
144 Hz x 90 kHz
Bulb life cycle
Side-by-Side, Crestron RoomView
Lens
Focus Type
Manual
Lens Aperture
F/2.6-2.81
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-15 / +15
Video Input
TV System
NTSC, SECAM, PAL
Video Interfaces
VGA, HDMI, DisplayPort, composite video, S-Video
Video Modes
Speakers
Integrated
Output Power / Channel
3 Watt
1 x DisplayPort - 20 pin DisplayPort , 2 x HDMI - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x 3D Sync in/out - 3 PIN mini-DIN , 1 x USB - 4 pin USB Type B
Carrying case, lens cover, wireless remote control
1 x VGA cable
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), security bar, keypad lock
Security Slot Type
Kensington security slot
Nominal Voltage
380 Watt
Power Consumption Stand by
1 Watt
32.6 cm
25.9 cm
10.9 cm
3.7 kg
Limited warranty - 2 years , Limited warranty - lamp - 1 year
5 °C
0 - 85%
Sound Emission
28 dB
96RM C2G 2m USB 2.0 A/B Cable - Black In Stock £3.82
96RM C2G HDMI to DisplayPort Adapter Converter In Stock £36.58
96RM C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.12
96RM C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.14
96RM C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
96RM C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £22.78
96RM C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £15.83
96RM C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.26
96RM C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.52
Brand: Optoma
Price Range Ex VAT: 750 - 1000
