Optoma X402 XGA 1024 x 768 HDMI VGA 3D Projector
Quicklinx: BXT0WS00 Mfr#: X402
Project bright vibrant widescreen presentations any time of day. Designed for meeting rooms and classrooms, the X402 boasts a long lamp life and energy-saving features which provide a low overall cost of ownership.
This projector has a built-in speaker, networking capabilites, Full 3D technology and can be easily connected via a HDMI cable, giving a clear projected image with sound. The lightweight projector can be installed or taken on the move in the handy carry bag for off-site meetings.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images.
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the "auto power off" feature automatically turns off the projector after a set period of time if it is not being used.
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp.
  • Long lamp life
    Reduce the number of lamp changes with lamp life of long hours.
  • Remote mouse and laser
    Keep your audience's attention focused on the right things using the simple, yet powerful remote with USB mouse control and built in laser pointer.
  • Networking and control
    Featuring a wide range of options you can control and monitor the projector remotely.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
Optoma X402 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Stereo speakers
Microdisplay
DarkChip 3
Brightness
4200 ANSI lumens
Contrast Ratio
20000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
260 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i
Speakers
Speaker(s) - integrated
306 Watt
31.46 cm x 22.36 cm x 10.17 cm
2.57 kg
3-year warranty
DLP projector
3D Capable
Built-in Devices
Stereo speakers
Projector
Microdisplay
DarkChip 3
Brightness
4200 ANSI lumens
Contrast Ratio
20000:1
Image Size
92 cm - 769 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.6 - 1.92:1
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
260 Watt
Bulb life cycle
Controls & Adjustments
Volume, brightness, keystone correction, zoom
OSD Languages
Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, AMX Device Discovery, Auto Power Off, Eco+ technology
Lens
Focus Type
Manual
Lens Aperture
F/2.4-2.66
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in / microphone input - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
306 Watt
Power Consumption Stand by
0.5 Watt
31.46 cm
22.36 cm
10.17 cm
2.57 kg
Limited warranty - 3 years
5 °C
31 dB
