Optoma X345 XGA 3200 Lumens Projector incl. 5 Year Warranty
Installation required? Contact us today!
Quicklinx: CJLNWS00 Mfr#: 95.74F01GC0E.WTPL05
Make your presentations count regardless of the ambient light level using the bright X345. Designed for business and educational environments, this small projector boasts accurate true-to-life color reproduction, color precision with sRGB colors; all your content will look crisp and natural. It also features long lamp life and energy-saving features will also provide you with a low overall cost of ownership. Easy to connect to with multiple inputs, a built-in speaker and USB power, you can easily connect a HDMI dongle or a laptop, PC or Blu-ray player for clear projected images with sound.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and games consoles.
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy if the projector is left running and no source is detected, the auto power off feature automatically turns off the projector after a set period of time.
  • Eco AV mute
    Stay in control of your presentation with eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed.
  • Amazing color
    Give powerful presentations and educational lessons with stunning colors. Optoma projectors provide you with reliable color performance suitable for any content and environment. From accurate sRGB colors for true life-like images to vibrant punchy presentations.
Optoma X345 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker, 0.55-inch TFT LCD
Microdisplay
DarkChip 3
Brightness
3200 ANSI lumens
Contrast Ratio
22000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
195 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
225 Watt
29.8 cm x 23 cm x 9.65 cm
2.41 kg
DLP projector
3D Capable
Built-in Devices
Projector
Microdisplay
DarkChip 3
Brightness
3200 ANSI lumens
Contrast Ratio
22000:1
Image Size
78 cm - 765 cm
Projection Distance
1.2 m - 9.1 m
Throw Ratio
1.49 - 1.93:1
Uniformity
75 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
195 Watt
Bulb life cycle
Auto Power Off, Eco+ technology
Lens
Focus Type
Manual
Lens Aperture
F/2.5-2.78
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A (power only)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
Power Source
AC
Nominal Voltage
225 Watt
Power Consumption Stand by
0.5 Watt
29.8 cm
23 cm
9.65 cm
2.41 kg
5 °C
0 - 85%
29 dB
