Make your presentations count regardless of the ambient light level using the bright X345. Designed for business and educational environments, this small projector boasts accurate true-to-life color reproduction, color precision with sRGB colors; all your content will look crisp and natural. It also features long lamp life and energy-saving features will also provide you with a low overall cost of ownership. Easy to connect to with multiple inputs, a built-in speaker and USB power, you can easily connect a HDMI dongle or a laptop, PC or Blu-ray player for clear projected images with sound.
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and games consoles. -
Eco+
Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption. -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy if the projector is left running and no source is detected, the auto power off feature automatically turns off the projector after a set period of time. -
Eco AV mute
Stay in control of your presentation with eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. -
Amazing color
Give powerful presentations and educational lessons with stunning colors. Optoma projectors provide you with reliable color performance suitable for any content and environment. From accurate sRGB colors for true life-like images to vibrant punchy presentations.
- Optoma X345 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker, 0.55-inch TFT LCD
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 22000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 195 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 225 Watt
- 29.8 cm x 23 cm x 9.65 cm
- 2.41 kg
- DLP projector
- 3D Capable
- Built-in Devices
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 22000:1
- Image Size
- 78 cm - 765 cm
- Projection Distance
- 1.2 m - 9.1 m
- Throw Ratio
- 1.49 - 1.93:1
- Uniformity
- 75 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 91.1 kHz
- Bulb type
- 195 Watt
- Bulb life cycle
- Auto Power Off, Eco+ technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.78
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A (power only)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 225 Watt
- Power Consumption Stand by
- 0.5 Watt
- 29.8 cm
- 23 cm
- 9.65 cm
- 2.41 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 29 dB
