The X319USTir, is perfect for businesses, schools and colleges. It is bright and uses IR interactive technology, enabling people to work simultaneously on the screen using pens. The high throw ratio means that it can project images from a small distance. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter.
Ultra-short throw
With an ultra-short throw lens, you can project an impressive image from a short distance. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease - perfect for interactive applications. -
IR pen interactive technology
Optoma's IR pen interactive technology enables two people to work simultaneously on the screen using a pen. It is easy to draw, annotate, zoom and rotate images on the projected screen. You can even open documents or browse the web without touching your computer. Designed for businesses, schools and colleges, multiple touch points allow for a more natural and intuitive way of interacting with digital content. -
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and highly-demanding games consoles. -
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers. -
Eco+ technology
Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption. -
Energy saving
Using the specially designed lamp modes, you can significantly reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the auto power off feature automatically turns off the projector after a set period of time if it is not being used. -
Remote mouse
Keep your audience's attention focused on the right things using the simple, yet powerful remote with USB mouse control. -
Amazing colors
For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multicolor processing technology.
- Optoma X319USTIR - DLP projector - ultra short-throw - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DMD Chip
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 18000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw fixed lens
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 235 Watt
- 38.5 cm x 31 cm x 9.9 cm
- 4.63 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 18000:1
- Image Size
- 178 cm - 254 cm
- Projection Distance
- 0.47 m - 0.68 m
- Throw Ratio
- 0.33:1
- Uniformity
- 85 %
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91.1 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Korean, Javanese
- BrilliantColor, 16:9 aspect ratio support, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Eco+ technology, IR pen interactive technology
Lens
- Lens Aperture
- F/2.4
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x USB - mini-USB Type B (management) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 (management) , 1 x USB (power only) - 4 pin mini-USB Type A (power only) , 1 x 3D Sync out , 1 x audio line-in - RCA x 2
- Included Accessories
- 2 Interactive Pens, wireless remote control
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 235 Watt
- Power Consumption Stand by
- 0.5 Watt
- 38.5 cm
- 31 cm
- 9.9 cm
- 4.63 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 26 dB
