Product
Optoma X319UST XGA Ultra-Short Throw Projector Inc Wall Mount
Quicklinx: CJLSWS00 Mfr#: 95.71K01GC0E
Portability: Non-portable
Hurry, only 2 left in stock!
£803.11 ex VAT
£963.73 inc VAT
The X319UST, is perfect for businesses, schools and colleges. It is bright and its throw ratio means that it can project a 100" image from shorter distance. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter. It provides a complete package for engaging learning with many features, including two HDMI inputs, powered USB port, powerful built-in speaker, improved lamp life, compact chassis and a handy mounting system for a fast and simple set-up.
  • Ultra short throw
    With an ultra-short throw lens, you can project an impressive image greater than 100" from shorter distance. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease. It is perfect for interactive applications.
  • High contrast
    Add more depth to your image with a high contrast projector. With brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma X319UST projector can display true 3D content from almost any 3D source. Support for rapid refresh rate provides ultra-smooth flicker free images.
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption drastically. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto Power Off feature
    There may be instances when the projector is left running when not in use. To help save energy, the Auto Power Off feature automatically turns off the projector after a set period of time if it is not being used.
Optoma X319UST - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
3200 ANSI lumens
Contrast Ratio
18000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
235 Watt
38.5 cm x 31 cm x 9.9 cm
4.57 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DMD Chip
Brightness
3200 ANSI lumens
Contrast Ratio
18000:1
Image Size
178 cm - 254 cm
Projection Distance
0.47 m - 0.68 m
Throw Ratio
0.33:1
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Korean, Javanese
BrilliantColor, 16:9 aspect ratio support, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Eco+ technology
Lens
Lens Aperture
F/2.4
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x USB - mini-USB Type B (management) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 (management) , 1 x USB (power only) - 4 pin mini-USB Type A (power only) , 1 x 3D Sync out
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
Nominal Voltage
235 Watt
Power Consumption Stand by
0.5 Watt
38.5 cm
31 cm
9.9 cm
4.57 kg
5 °C
0 - 85%
26 dB
Brand: Optoma
Price Range Ex VAT: 750 - 1000
