The X319UST, is perfect for businesses, schools and colleges. It is bright and its throw ratio means that it can project a 100" image from shorter distance. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter. It provides a complete package for engaging learning with many features, including two HDMI inputs, powered USB port, powerful built-in speaker, improved lamp life, compact chassis and a handy mounting system for a fast and simple set-up.
Ultra short throw
With an ultra-short throw lens, you can project an impressive image greater than 100" from shorter distance. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease. It is perfect for interactive applications. -
High contrast
Add more depth to your image with a high contrast projector. With brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma X319UST projector can display true 3D content from almost any 3D source. Support for rapid refresh rate provides ultra-smooth flicker free images. -
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers. -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption drastically. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off. -
Auto Power Off feature
There may be instances when the projector is left running when not in use. To help save energy, the Auto Power Off feature automatically turns off the projector after a set period of time if it is not being used.
- Optoma X319UST - DLP projector - ultra short-throw - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DMD Chip
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 18000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw fixed lens
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 235 Watt
- 38.5 cm x 31 cm x 9.9 cm
- 4.57 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 18000:1
- Image Size
- 178 cm - 254 cm
- Projection Distance
- 0.47 m - 0.68 m
- Throw Ratio
- 0.33:1
- Uniformity
- 85 %
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91.1 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Korean, Javanese
- BrilliantColor, 16:9 aspect ratio support, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Eco+ technology
Lens
- Lens Aperture
- F/2.4
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x USB - mini-USB Type B (management) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 (management) , 1 x USB (power only) - 4 pin mini-USB Type A (power only) , 1 x 3D Sync out
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 235 Watt
- Power Consumption Stand by
- 0.5 Watt
- 38.5 cm
- 31 cm
- 9.9 cm
- 4.57 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 26 dB
