Optoma X316ST XGA 1024 x 768 HDMI VGA 3D Projector
Quicklinx: BXSZWS00 Mfr#: X316ST
The Optoma X316ST is the perfect short throw projector solution for use in classrooms, training rooms, higher education, houses of worship and digital signage applications.
With a powerful 3200 lumens bright image, a stunning 20,000:1 contrast ratio and Dynamic Black technology, the X316ST delivers bright large-screen short throw presentations with superb image clarity, razor sharp detail and remarkable color accuracy.
It provides complete connectivity for compatibility with analog and digital sources, including HDMI with Full 3D capability, 2x VGA-in, VGA loop through, 2x audio-in, audio-out, RJ45, RS-232 control and advanced remote with laser and mouse control. Ultra-long 8000 hours lamp life and filter-free design minimize the cost of operation.
Optoma X316ST - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Contrast Ratio
20000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
249 Watt
31.5 cm x 22.4 cm x 10.2 cm
2.76 kg
3-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Contrast Ratio
20000:1
Image Size
1 m - 5 m
Projection Distance
0.75 m
Throw Ratio
0.617:1
Uniformity
115 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
210 Watt
Bulb life cycle
BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, AMX Device Discovery, Eco+ technology, ProJect Green
Lens
Focus Type
Manual
Lens Aperture
F/2.7
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Output Power / Channel
10 Watt
1 x component video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in / microphone input - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB - mini-USB Type B , 1 x network - RJ-45
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
249 Watt
Power Consumption Stand by
0.5 Watt
31.5 cm
22.4 cm
10.2 cm
2.76 kg
Limited warranty - 3 years , Limited warranty - lamp - 90 days
5 °C
29 dB
