The Optoma X316ST is the perfect short throw projector solution for use in classrooms, training rooms, higher education, houses of worship and digital signage applications.
With a powerful 3200 lumens bright image, a stunning 20,000:1 contrast ratio and Dynamic Black technology, the X316ST delivers bright large-screen short throw presentations with superb image clarity, razor sharp detail and remarkable color accuracy.
It provides complete connectivity for compatibility with analog and digital sources, including HDMI with Full 3D capability, 2x VGA-in, VGA loop through, 2x audio-in, audio-out, RJ45, RS-232 control and advanced remote with laser and mouse control. Ultra-long 8000 hours lamp life and filter-free design minimize the cost of operation.
- Optoma X316ST - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 210 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 249 Watt
- 31.5 cm x 22.4 cm x 10.2 cm
- 2.76 kg
- 3-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 1 m - 5 m
- Projection Distance
- 0.75 m
- Throw Ratio
- 0.617:1
- Uniformity
- 115 %
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 210 Watt
- Bulb life cycle
- BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, AMX Device Discovery, Eco+ technology, ProJect Green
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.7
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Output Power / Channel
- 10 Watt
- 1 x component video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in / microphone input - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB - mini-USB Type B , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 249 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 22.4 cm
- 10.2 cm
- 2.76 kg
- Limited warranty - 3 years , Limited warranty - lamp - 90 days
- 5 °C
- 40 °C
- Sound Emission (Economic Mode)
- 29 dB
