Simple to connect to with HDMI connectivity the X316 is ideal for use in a meeting room or classroom. The bright 3200L with 15000:1 contrast allows you to project bright, crystal clear images with superb colors using DLP, BrilliantColor and dynamic eco+ technology.
The X316 also provides you with energy and cost saving features with an incredible lamp life of up to 10000 hours. It also incorporates a built in speaker, full 3D technology and wireless capabilities allowing you to present wirelessly from a PC or mobile device with ease.
Dynamic mode
Saving energy saves money! Dynamic mode reduces the power consumption to as little as 30%. This intelligent feature can more than double your expected lamp life, lowering the total cost of ownership and reducing maintenance. -
Eco AV mute
Stay in control of your presentation with the eco AV mute feature. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also instantly reduces the power consumption to 25%, further prolonging the life of your lamp. -
Rapid off
It takes less than 10 seconds for the projector to power up and shutdown, saving both time and energy. -
Quick resume
Save time by not waiting for the projector to cool down before it can power up again. If the projector is accidentally turned off, this feature allows the projector to be instantly powered on again, if selected within a period of 100 seconds. -
Full 3D
Using the inherent speed of DLP technology, the Optoma X316, full 3D projector can display true 3D content form any 3D display device, such as 3D Blu-ray, PS3, Xbox and Sky3D. -
Audio performance
Built-in 2 W speaker offers excellent audio support. The X316 is easy to set up without the need for costly external speakers. -
Brightness where it matters
Room lighting can be unpredictable for the business traveler; you never know what to expect. The X316 has a powerful lamp producing 3000 ANSI lumens, so you can be sure your presentation will be bright and clear. -
Cost Saving - long lamp life
Reduce the number of lamp changes with lamp life of up to 10000 hours using the education cycle. -
Clear, focused images
Produce a stunning 15000:1 contrast ratio for pin sharp graphics and crystal clear text using the unique dynamic mode feature. Combined with DarkChip3 technology for texas instruments, dynamic mode automatically adjusts the lamp output, based on the brightness information of each frame; to create a stunning high contrast ratio. Bright scenes are crisp and clear, while dark scenes remain detailed with deep blacks which gives exceptional light and shade detail. -
Digital connectivity
Simple and easy - connect using a HDMI cable for a digital audio and video connection to your projector giving you a clear projected image with sound.
- Optoma X316 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 15000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 225 Watt
- 31.46 cm x 22.26 cm x 10.17 cm
- 2.35 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 15000:1
- Image Size
- 70 cm - 762 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.95 - 2.15:1
- Uniformity
- 80 %
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- BrilliantColor, DarkChip3 single-chip DLP technology, Eco+ technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.55
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Output Power / Channel
- 2 Watt
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x composite video input - RCA
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Mounting Kit
- Optional
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Voltage Required
- 225 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.46 cm
- 22.26 cm
- 10.17 cm
- 2.35 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 29 dB
