Optoma X305ST DLP XGA 3000 Lumens Projector
Quicklinx: 8RWKWS00 Mfr#: 95.8TM01GC0E
The XGA short throw, Full 3D X305ST at 3000 ANSI lumens is designed to display bright, rich, colorful, crystal-clear images for both the education and business environments.
Captivate your audience, increase their learning potential and help improve results with lessons in crystal clear 2D or incredible 3D.
Perfect for installations with interactive whiteboards ensures teaching and business environments have the right tools for engaging and presenting to their audience without shadows and screen glare.
Incredible lamp life of up to 10000 hours combined with Eco+ technology provides energy and money saving features.
  • Eco+ mode
    Saving energy saves money! Eco+ technology reduces the power consumption to as little as 30%. This intelligent feature also has a positive effect on the lamp life, increasing it up to 70% while lowering the total cost of ownership and reducing maintenance.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy if the projector is left running and no source is detected, the "Auto Power Off" feature automatically turns off the projector after a set period of time.
  • Eco AV mute
    Stay in control of your presentation with the Eco AV mute feature. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also instantly reduces the power consumption to 30%, further prolonging the life of your lamp.
  • Inspire your students
    Teaching in 3D is excellent in education technology, opening up avenues of learning for both educators and students alike. Engage and inspire your students with lessons taught in 3D - explore the world, travel through space, see inside the body and bring excellent ideas to life. Optoma 3D projectors take teaching to a whole new level of immersion and enjoyment at no extra cost!
  • Short throw lens
    The X305ST can project an impressive 60" diagonal image from just 77 cm from the screen. Standalone or wall mounted, the X305ST eliminates shadows on the screen and allows you to present with ease.
  • Bright, detailed and colorful projection
    Grab your audience's attention with bright, vivid projected images thanks to the BrilliantColor technology incorporated within the X305ST. Preset display modes allow you to achieve a perfect image on a variety of surfaces including screens and interactive whiteboards
  • Clear, focused images
    Lessons in the classroom and presentations in the boardroom demand sharp, flawless images. DarkChip3 technology from Texas Instruments produces a stunning 15000:1 contrast ratio for pin sharp graphics and crystal-clear text. Crisper whites and ultra-rich blacks make images come alive and text easier to read. To retain image clarity, Optoma projectors are designed with DLP technology preventing degradation over time to give consistent pixel performance.
  • AMX compatibility
    Dynamic discovery protocol is incorporated into the X305ST. This feature allows for easy installation with AMX control systems.
  • Direct power on
    Start up time is significantly reduced as standby mode is bypassed when the power cable is inserted into an active power outlet. This eliminates the need to use the 'Power' button on the remote control or the projector keypad.
  • Keypad lock
    Once enabled, prevents unauthorized adjustments ensuring the projector can only be controlled via the remote control.
Optoma X305ST - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
2800 lumens
Contrast Ratio
10000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
205 Watt
28.8 cm x 22 cm x 8.6 cm
2.55 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
2800 lumens
Contrast Ratio
10000:1
Image Size
1 m - 5 m
Projection Distance
0.5 m - 2.5 m
Throw Ratio
0.626:1
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91 kHz
Bulb life cycle
BrilliantColor, Eco+ technology
Lens
Lens Aperture
F/2.8
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Output Power / Channel
2 Watt
1 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Lens cover, remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Nominal Voltage
205 Watt
Power Consumption Stand by
0.5 Watt
28.8 cm
22 cm
8.6 cm
2.55 kg
5 °C
0 - 85%
29 dB
8RWK C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
8RWK C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.86
8RWK C2G 5m Select High Speed HDMI with Ethernet In Stock £22.88
8RWK C2G 10m Select High Speed HDMI with Ethernet In Stock £43.91
8RWK C2G 15m Select High Speed HDMI with Ethernet In Stock £59.48
8RWK C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
