Optoma X304M 3000 ANSI Lumens XGA Projector
Quicklinx: CTL0WS00 Mfr#: E1P1D0H1E001
Type: XGA projector
Brightness: 3000ANSI lumens
Portability: Portable
Resolution: 1024 x 768
£613.40 ex VAT
£736.08 inc VAT
The Optoma X304M is the perfect projector for mobile professionals looking for a powerful, compact projector that is capable of delivering stunning presentations. Its 3000 ANSI lumens and 10,000:1 contrast ratio provide the brightness level you need to make your presentations stand out.
The Optoma X304M offers the level of connectivity necessary to satisfy your current and future needs, and its intuitive menu system makes it incredibly easy to operate. Designed for road warriors, the X304M is small in size, lightweight and strong in performance and reliability. Its DLP light engine ensures that your projector will deliver the same outstanding performance year after year.
DLP projector
3D Capable
Yes (3D glasses sold separately)
Projector
Brightness
3000 ANSI lumens
Contrast Ratio
10000:1
Image Size
68 cm - 526 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.9 - 2.2:1
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
134.2 million colours
Max Sync Rate (V x H)
87 Hz x 91.4 kHz
Bulb type
220 Watt
Bulb life cycle
Up to 4000 hours - normal mode , Up to 5000 hours - economic mode
Controls & Adjustments
Keystone correction
BrilliantColor, ProJect Green
Lens
Lens Aperture
F/2.55-2.72
Zoom Type
Manual
Zoom Factor
1.15x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
RGB, composite video
Video Interfaces
VGA, HDMI, composite video
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
1 x USB , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A
Carrying case, lens cover, remote control
1 x VGA cable , 1 x USB cable , 1 x composite video cable
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), password protection
Security Slot Type
Kensington security slot
RoHS
Nominal Voltage
280 Watt
Power Consumption Stand by
0.5 Watt
22 cm
17.8 cm
7.1 cm
1.4 kg
5 °C
0 - 80%
33 dB
Type: XGA projector
Brand: Optoma
Price Range Ex VAT: 500 - 750
