WPS Pro is a professional wireless presentation gateway. By enabling "interactive" and "wireless" functions, you can throw your presentations wirelessly from a PC or mobile devices to a projector! And you can use your pad, tab or phone to control your PC, or view the presenting slides!
- Optoma WPS Pro - presentation server - Wi-Fi
- Presentation server
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- OS Required
- Apple MacOS X 10.7 or later, Microsoft Windows Vista / XP / 7 / 8, Apple iOS 3.2 or later, Android 2.4 or later
- 15 cm x 5.9 cm x 2.5 cm
- 243 g
- 15 cm
- 5.9 cm
- 2.5 cm
- 243 g
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- 4 to 1 split-screen function
- Encryption Algorithm
- WPA, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna Qty
- 2
- 1 x VGA output - HD-15 , 1 x HDMI output , 1 x 100Base-TX - RJ-45 , 1 x audio line-out - mini-jack , 3 x USB 2.0 - Type A
- FCC Part 15 B, Directive 1999/5/EC, Directive 2004/108/EC, Directive 2006/95/EC
- Power Device
- External power adapter
- OS Required
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
