Product
Optoma WPS Pro Wireless Box
Quicklinx: C8SGWS00 Mfr#: H1AXW0000007
  • IEEE 802.11n
WPS Pro is a professional wireless presentation gateway. By enabling "interactive" and "wireless" functions, you can throw your presentations wirelessly from a PC or mobile devices to a projector! And you can use your pad, tab or phone to control your PC, or view the presenting slides!
Optoma WPS Pro - presentation server
Presentation server
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Apple MacOS X 10.7 or later, Microsoft Windows Vista / XP / 7 / 8, Apple iOS 3.2 or later, Android 2.4 or later
15 cm x 5.9 cm x 2.5 cm
243 g
Presentation server
15 cm
5.9 cm
2.5 cm
243 g
External
Wireless, wired
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
4 to 1 split-screen function
Encryption Algorithm
WPA, WPA2-PSK, WEP
Aerial
Antenna Qty
2
1 x VGA output - HD-15 , 1 x HDMI output , 1 x 100Base-TX - RJ-45 , 1 x audio line-out - mini-jack , 3 x USB 2.0 - Type A
FCC Part 15 B, Directive 1999/5/EC, Directive 2004/108/EC, Directive 2006/95/EC
External power adapter
C8SG C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
C8SG C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.46
C8SG C2G 5m Select High Speed HDMI with Ethernet In Stock £21.58
C8SG C2G 10m Select High Speed HDMI with Ethernet In Stock £41.46
C8SG C2G 15m Select High Speed HDMI with Ethernet In Stock £56.17
C8SG C2G Pro HDMI to VGA Converter In Stock £51.78
C8SG C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
