Product
Brand
Optoma W415E WXGA 1280 x 800 HDMI VGA 3D Projector
Quicklinx: BXSXWS00 Mfr#: W415e
Widescreen HD Ready WXGA clarity combined with vertical lens shift and amazing colors, make the compact Optoma W415e projector an ideal candidate for both desktop and installation use.
Full support for Crestron Roomview, Telnet, Extron IP Link, AMX dynamic device discovery and PJ-Link protocols, allow almost all aspects of the W415e to be controlled across a network, keeping you in control, wherever you are.
The environmentally friendly W415e has energy saving features including Eco and dynamic black power management, saving you both time and money.
Optoma W415e - DLP projector - portable - 3D
DLP projector - High Definition 720p
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
4500 ANSI lumens
Contrast Ratio
15000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens Shift Direction
Vertical
Bulb type
280 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 7000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 525i, 525p, 625p, 625i, 576i, 576p
Speakers
Speaker(s) - integrated
290 Watt
28.6 cm x 26.6 cm x 12.4 cm
2.7 kg
5 years warranty
DLP projector - HD 720p
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
4500 ANSI lumens
Contrast Ratio
15000:1
Image Size
63 cm - 805 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.46 - 2.2:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
280 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
BrilliantColor, 16:9 aspect ratio support, PJlink, Crestron RoomView, 16:10 aspect ratio support, 4:3 aspect ratio support, AMX Device Discovery, Eco+ technology, V.Lens Shift
Lens
Lens Aperture
F/2.42-2.97
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Vertical
Vertical Lens Shift
15%
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
HDMI, component video, composite video, S-Video, RGB
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - mini-USB Type B (management)
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS
Nominal Voltage
290 Watt
Power Consumption Stand by
0.5 Watt
28.6 cm
26.6 cm
12.4 cm
2.7 kg
Limited warranty - 5 years
32 dB
