Optoma W345 WXGA 3300 Lumens Projector incl. 5 Year Warranty
Quicklinx: CJLPWS00 Mfr#: 95.74G01GC0E.WTPL05
Make your presentations count regardless of the ambient light level using the bright HD ready W345. Designed for business and educational environments. This small projector boasts accurate true to life color reproduction color precision with sRGB colors; all your content will look crisp and natural. It also features long lamp life and energy-saving features will also provide you with a low overall cost of ownership.
Easy to connect to with multiple inputs, a built-in speaker and USB power, you can easily connect a HDMI dongle such as the Google Chromecast and the Optoma HDCast Pro or a laptop, PC or Blu-ray player for clear projected images with sound.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy if the projector is left running and no source is detected, the "Auto power off" feature automatically turns off the projector after a set period of time.
  • Remote mouse and laser
    Keep your audience's attention focussed on the right things using the simple, yet powerful remote with USB mouse control and built in laser pointer.
  • Direct power off
    You can powered off your projector immediately or directly at the mains. Should you require to turn you projector back on immediately it will take about 90 seconds to start up.
  • Replace your LCD projector
    Upgrade your LCD projector with an Optoma DLP projector for higher contrast and accurate color reproduction. Designed with a flexible 1.3x zoom and a throw ratio equivalent to EPSON, NEC, Hitachi, Panasonic and Sony LCD projectors; You can now minimize installation costs and easily replace your old LCD projector without having to move the existing ceiling mount or white board.
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp.
  • Amazing color
    Give powerful presentations and educational lessons with stunning colors. Optoma projectors provide you with reliable color performance suitable for any content and environment. From accurate sRGB colors for true life like images to vibrant punchy presentations.
  • USB power
    Use the USB-Power to power an HDMI dongle, such as Google Chromecast.
Optoma W345 - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3300 ANSI lumens
Contrast Ratio
22000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
195 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Speakers
Speaker(s) - integrated
225 Watt
29.8 cm x 23 cm x 9.65 cm
2.41 kg
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3300 ANSI lumens
Contrast Ratio
22000:1
Image Size
92 cm - 765 cm
Projection Distance
1.2 m - 7.7 m
Throw Ratio
1.19 - 1.54:1
Uniformity
75 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
195 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, 4:3 aspect ratio support, Eco+ technology
Lens
Lens Aperture
F/2.5-2.78
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 1 x USB (power only) - 4 pin USB Type A , 1 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA , 1 x serial RS-232
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
Nominal Voltage
225 Watt
Power Consumption Stand by
0.5 Watt
29.8 cm
23 cm
9.65 cm
2.41 kg
5 °C
0 - 85%
29 dB
