Project your presentations in HD effortlessly any time on day with the bright W340. Designed for meeting rooms and classrooms, this small projector boasts high brightness, long lamp life and energy-saving features to provide you with a low overall cost of ownership. Easy to connect to with two HDMI inputs, MHL, USB power and a built-in speaker, this projector is perfect for connecting HDMI dongles or a laptop, PC or Blu-ray player for clear projected images with sound. Portable and lightweight projector can be installed or taken on the move for off-site meetings or a friend's house.
MHL
Turn your projector into a smart display by connecting your smartphone or tablet with a single cable using MHL, enabling you to view presentations and documents, stream videos and share photos on the big screen. -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image, when no longer needed. This also reduces the power consumption, further prolonging the life of your lamp. -
Auto power off
There may be instances, when the projector is left running, when not in use. To help save energy, if the projector is left running and no source is detected, the “auto power off” feature automatically turns off the projector after a set period of time. -
High contrast
Add more depth to your image with a high-contrast projector, with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
- Optoma W340P - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 195 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 225 Watt
- 29.8 cm x 23 cm x 9.65 cm
- 2.17 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 68 cm - 804 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.54 - 1.7:1
- Uniformity
- 75 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91.1 kHz
- Bulb type
- 195 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
- BrilliantColor, 16:9 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, Eco+ technology, ProJect Green
Lens
- Lens Aperture
- F/2.5-2.6
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB (power only) - 4 pin USB Type A (power only)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 225 Watt
- Power Consumption Stand by
- 0.5 Watt
- 29.8 cm
- 23 cm
- 9.65 cm
- 2.17 kg
- 5 °C
- 40 °C
- 10 - 85% (non-condensing)
- Sound Emission (Economic Mode)
- 29 dB
