Optoma W340P 3400 ANSI lumens DLP Projector
Quicklinx: CYMYWS00 Mfr#: 95.72H02GC1E.P
Type: DLP Projector
Brightness: 3400ANSI lumens
Portability: Portable
Resolution: 1920 x 1080
£391.30 ex VAT
£469.56 inc VAT
Project your presentations in HD effortlessly any time on day with the bright W340. Designed for meeting rooms and classrooms, this small projector boasts high brightness, long lamp life and energy-saving features to provide you with a low overall cost of ownership. Easy to connect to with two HDMI inputs, MHL, USB power and a built-in speaker, this projector is perfect for connecting HDMI dongles or a laptop, PC or Blu-ray player for clear projected images with sound. Portable and lightweight projector can be installed or taken on the move for off-site meetings or a friend's house.
  • MHL
    Turn your projector into a smart display by connecting your smartphone or tablet with a single cable using MHL, enabling you to view presentations and documents, stream videos and share photos on the big screen.
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image, when no longer needed. This also reduces the power consumption, further prolonging the life of your lamp.
  • Auto power off
    There may be instances, when the projector is left running, when not in use. To help save energy, if the projector is left running and no source is detected, the “auto power off” feature automatically turns off the projector after a set period of time.
  • High contrast
    Add more depth to your image with a high-contrast projector, with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
Optoma W340P - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
195 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
225 Watt
29.8 cm x 23 cm x 9.65 cm
2.17 kg
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Contrast Ratio
20000:1
Image Size
68 cm - 804 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.54 - 1.7:1
Uniformity
75 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
195 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, Eco+ technology, ProJect Green
Lens
Lens Aperture
F/2.5-2.6
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB (power only) - 4 pin USB Type A (power only)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
Nominal Voltage
225 Watt
Power Consumption Stand by
0.5 Watt
29.8 cm
23 cm
9.65 cm
2.17 kg
5 °C
10 - 85% (non-condensing)
29 dB
Type: DLP Projector
Brand: Optoma
Price Range Ex VAT: 300 - 500
