Optoma W330 WXGA 1280 x 800  3000 Lumens 3D Projector
Quicklinx: C3YLWS00 Mfr#: 95.72H01GC1E
Portability: Portable
£324.81 ex VAT
£389.77 inc VAT
Project bright vibrant presentations in HD effortlessly any time on day. Designed for meeting rooms and classrooms, the W330 boasts sRGB accurate true to life color reproduction, long lamp life and energy-saving features to provide you with a low overall cost of ownership.
This projector is easy to connect to with multiple inputs and a built-in speaker. Perfect for connecting a laptop, PC or Blu-ray player for clear projected images with sound.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used
  • Long lamp life
    Reduce the number of lamp changes with lamp life of long hours using the Education Cycle.
Optoma W330 - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
195 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
225 Watt
29.8 cm x 23 cm x 9.65 cm
2.17 kg
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1
Image Size
68 cm - 804 cm
Projection Distance
1 m - 12 m
Throw Ratio
1.55 - 1.73:1
Uniformity
75 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
195 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, Eco+ technology
Lens
Lens Aperture
F/2.5-2.67
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x management - mini-USB Type B , 1 x HDMI - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
Nominal Voltage
225 Watt
Power Consumption Stand by
0.5 Watt
29.8 cm
23 cm
9.65 cm
2.17 kg
5 °C
10 - 85% (non-condensing)
29 dB
C3YL C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.32
C3YL C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.57
Brand: Optoma
Price Range Ex VAT: 300 - 500
