The W320USTi is perfect for businesses, schools and colleges. It is bright and uses an advanced TouchBeam finger-touch interactive technology, enabling several people to work simultaneously on the screen without using a pen. The optimal throw ratio allows it to project an image from less than 0.5 m away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter (s). The projector provides a complete package for engaging learning with many convenient features, including two HDMI inputs, powered USB port, powerful built-in speaker, improved lamp life, compact chassis and a convenient mounting system for a fast and simple setup.
Ultra short throw
With an ultra-short throw lens, you can project an impressive image from just 0.5 m away. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease; perfect for interactive applications. -
TouchBeam interactive technology
Optoma's TouchBeam finger-touch interactive technology enables several people to work simultaneously on the screen without using a pen. It is easy to draw, annotate, zoom and rotate images on the projected screen. You can even open documents or browse the web without touching your computer. Designed for businesses, schools and colleges, multiple touch points allow for a more natural and intuitive way of interacting with digital content. -
High contrast
Add more depth to your image with a high contrast projector - with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the advanced games consoles. Support for rapid refresh rate provides ultra-smooth flicker-free images. -
Integrated speaker
The built-in speaker offers excellent audio support. It is easy to set up without the need for any external speakers. -
Energy saving
Using the specially designed lamp modes, you can greatly reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the Auto Power Off feature automatically turns off the projector after a set period of time if it is not being used. -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also greatly reduces the power consumption, further prolonging the life of your lamp. -
Remote mouse
Keep your audience's attention focused on the right things using the simple, yet powerful remote with USB mouse control. -
Amazing colors
For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multicolor processing technology.
- Optoma W320USTiP - DLP projector - ultra short-throw - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw fixed lens
- Bulb type
- 260 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 310 Watt
- 38.5 cm x 31 cm x 9.9 cm
- 4.85 kg
- Pricing Type
- Public Sector only
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 216 cm - 292 cm
- Projection Distance
- 0.49 m - 0.66 m
- Throw Ratio
- 0.27:1
- Uniformity
- 85 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 260 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
- BrilliantColor, 16:9 aspect ratio support, PJlink, Crestron RoomView, 16:10 aspect ratio support, 4:3 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology, TouchBeam interactive technology
Lens
- Lens Aperture
- F/2.4
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x HDMI - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x USB , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x 3D Sync out
- Included Accessories
- 2 Interactive Pens, wireless remote control, TouchBeam interactive module
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Pricing Type
- Power Source
- AC
- Voltage Required
- 310 Watt
- Power Consumption Stand by
- 0.5 Watt
- 38.5 cm
- 31 cm
- 9.9 cm
- 4.85 kg
- Limited warranty - 3 years , Limited warranty - lamp - 3 years
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 28 dB
