Optoma W320USTiP Interactive Ultra Short Throw Projector
Quicklinx: C6J0WS00 Mfr#: 95.72702GC0E.P
The W320USTi is perfect for businesses, schools and colleges. It is bright and uses an advanced TouchBeam finger-touch interactive technology, enabling several people to work simultaneously on the screen without using a pen. The optimal throw ratio allows it to project an image from less than 0.5 m away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter (s). The projector provides a complete package for engaging learning with many convenient features, including two HDMI inputs, powered USB port, powerful built-in speaker, improved lamp life, compact chassis and a convenient mounting system for a fast and simple setup.
  • Ultra short throw
    With an ultra-short throw lens, you can project an impressive image from just 0.5 m away. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease; perfect for interactive applications.
  • TouchBeam interactive technology
    Optoma's TouchBeam finger-touch interactive technology enables several people to work simultaneously on the screen without using a pen. It is easy to draw, annotate, zoom and rotate images on the projected screen. You can even open documents or browse the web without touching your computer. Designed for businesses, schools and colleges, multiple touch points allow for a more natural and intuitive way of interacting with digital content.
  • High contrast
    Add more depth to your image with a high contrast projector - with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the advanced games consoles. Support for rapid refresh rate provides ultra-smooth flicker-free images.
  • Integrated speaker
    The built-in speaker offers excellent audio support. It is easy to set up without the need for any external speakers.
  • Energy saving
    Using the specially designed lamp modes, you can greatly reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the Auto Power Off feature automatically turns off the projector after a set period of time if it is not being used.
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also greatly reduces the power consumption, further prolonging the life of your lamp.
  • Remote mouse
    Keep your audience's attention focused on the right things using the simple, yet powerful remote with USB mouse control.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multicolor processing technology.
Optoma W320USTiP - DLP projector - ultra short-throw - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
4000 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
260 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
Video Input
RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
310 Watt
38.5 cm x 31 cm x 9.9 cm
4.85 kg
Pricing Type
Public Sector only
3-year warranty
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DarkChip 3
Brightness
4000 ANSI lumens
Contrast Ratio
20000:1
Image Size
216 cm - 292 cm
Projection Distance
0.49 m - 0.66 m
Throw Ratio
0.27:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
260 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, PJlink, Crestron RoomView, 16:10 aspect ratio support, 4:3 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology, TouchBeam interactive technology
Lens
Lens Aperture
F/2.4
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x USB , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x 3D Sync out
2 Interactive Pens, wireless remote control, TouchBeam interactive module
1 x VGA cable , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Pricing Type
Public Sector only
Power Source
AC
310 Watt
Power Consumption Stand by
0.5 Watt
38.5 cm
31 cm
9.9 cm
4.85 kg
Limited warranty - 3 years , Limited warranty - lamp - 3 years
5 °C
0 - 85%
28 dB
