Optoma W319USTir WXGA Ultra-Short Throw Pen Inc Wall Mount
Quicklinx: CJLWWS00 Mfr#: 95.71L03GC0E
The W319USTir, is perfect for businesses, schools and colleges. It is bright (3300 lumens) and uses IR interactive technology, enabling people to work simultaneously on the screen using a pen. The throw ratio of 0.27:1 means that it can project a 100" image from less than 24 inches away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter.
It provides a complete package for engaging learning with many features, including two HDMI inputs, powered USB port, powerful 16-Watt built-in speaker, improved lamp life, compact chassis and a completely mounting system for a fast and simple set-up.
  • Ultra short throw
    With an ultra-short throw lens, you can project an impressive image greater than 100" from just 24 inches away. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease; perfect for interactive applications.
  • IR pen interactive technology
    Optoma's IR pen interactive technology enables two people to work simultaneously on the screen using a pen. It is easy to draw, annotate, zoom and rotate images on the projected screen. You can even open documents or browse the web without touching your computer. Designed for businesses, schools and colleges, multiple touch points allow for a more natural and intuitive way of interacting with digital content.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images.
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
Optoma W319USTir - DLP projector - ultra short-throw - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
3300 ANSI lumens
Contrast Ratio
18000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
235 Watt
38.5 cm x 31 cm x 12 cm
4.63 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DMD Chip
Brightness
3300 ANSI lumens
Contrast Ratio
18000:1
Image Size
216 cm - 292 cm
Projection Distance
0.49 m - 0.66 m
Throw Ratio
0.27:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Korean, Javanese
BrilliantColor, 16:9 aspect ratio support, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Eco+ technology, IR pen interactive technology
Lens
Lens Aperture
F/2.4
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x USB - mini-USB Type B (management) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 (management) , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x 3D Sync out , 1 x audio line-in - RCA x 2
2 Interactive Pens, wireless remote control
1 x VGA cable , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
235 Watt
Power Consumption Stand by
0.5 Watt
38.5 cm
31 cm
12 cm
4.63 kg
5 °C
0 - 85%
26 dB
