Optoma W319UST DLP 3D Projector 3300 ANSI Lumens WXGA
Quicklinx: CGLXWS00 Mfr#: 95.71L01GC0E
The W319UST, is perfect for businesses, schools and colleges. It is bright (3300 lm) and a throw ratio of 0.27:1 means that it can project a 100? image from less than 0.5 m away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter. It provides a complete package for engaging learning with many advanced features, including two HDMI inputs, powered USB port, powerful 16 W built-in speaker, improved lamp life, compact chassis and a completely ultimate mounting system for a fast and simple set up.
  • Ultra short throw
    With an ultra-short throw lens, you can project an impressive image greater than 100? from just 55 cm away. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease; perfect for interactive applications.
  • High contrast
    Add more depth to your image with a high-contrast projector; images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma W319UST can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the advanced games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker-free images.
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption drastically. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the auto power off feature automatically turns off the projector after a set period of time if it is not being used.
  • Long lamp life
    Reduce the number of lamp changes with lamp life of many hours.
  • Remote mouse
    Keep your audience's attention focused on the right things using the simple, yet powerful remote with USB mouse control.
  • Networking and control
    Featuring a wide range of options you can remotely control and monitor the projector. Optoma W319UST comes with an extensive set of RS-232 commands making it simple and easy to manage using any control system. Dynamic discovery protocol is incorporated into the projector allowing for easy installation with AMX control systems.
  • Amazing colors
    For vibrant, natural looking images, Optoma incorporates BrilliantColor multi-color processing technology.
Optoma W319UST - DLP projector - ultra short-throw - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3300 ANSI lumens
Contrast Ratio
18000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
235 Watt
38.5 cm x 31 cm x 12 cm
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DarkChip 3
Brightness
3300 ANSI lumens
Contrast Ratio
18000:1
Image Size
216 cm - 292 cm
Projection Distance
0.49 m - 0.66 m
Throw Ratio
0.27:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
190 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Thai, Slovak, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology
Lens
Lens Aperture
F/2.4
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x USB , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x 3D Sync out
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
235 Watt
Power Consumption Stand by
0.5 Watt
38.5 cm
31 cm
12 cm
5 °C
0 - 85%
26 dB
