Optoma W304M WXGA DLP 3100 Lumens Projector
Installation required? Contact us today!
Quicklinx: 8Q24WS00 Mfr#: W304M
Type: DLP Projector
Brightness: 3100ANSI lumens
Contrast Ratio: 10000:1
Portability: Portable
Resolution: 1280 x 800
£691.53 ex VAT
£829.83 inc VAT
Ideally partnered with a widescreen notebook, HD sources or a mobile device, the W304M delivers bright vivid presentations and videos in the office or on the road.
This travel-friendly projector incorporates a staggering 3100 ANSI lumens allowing you to project bright, crystal clear presentations during the day, leaving your audience speechless every time the projector is turned on.
Being small doesn't mean that you miss out on specification though, the W304M incorporates a built in speaker, HDMI connectivity, Full 3D technology and wireless capabilities allowing you to project wirelessly from a laptop or mobile device. It also comes with a convenient carry bag for easy transportation.
Projecting with laptops, Macs or even tablets has never been so easy.
  • Ultra portable
    The W304M is ultra light and ultra portable, coupled with the included carry case make it ideal for presentations on the go.
  • Brightness where it matters
    Room lighting can be unpredictable for the business traveler; you never know what to expect. The W304M has a powerful lamp producing 3100 ANSI lumens, so you can be sure your presentation will be bright and clear.
  • Rapid shut down
    Pack up your projector and go after 10 seconds from pressing the power button with rapid shutdown, saving you both time and money.
  • True WXGA resolution
    The W304M is the perfect companion for widescreen laptops. Your presentations will appear as sharp and detailed as they do on your widescreen laptop in WXGA (1280 x 800) resolution. WXGA resolution gives 30% more pixels than XGA.
  • Amazing colors
    The W304M incorporates BrilliantColor technology to produce stunningly bright images with perfectly balanced life-like colors.
  • Clear, focused images
    Be sure to have your audience's attention during a presentation with a stunning 10000:1 contrast ratio for pin sharp graphics and crystal clear text. Crisper whites and ultra-rich make images come alive and text easier to read - ideal for business and education presentations and the occasional movie.
  • Full 3D ready
    Using the inherent speed of DLP technology, The Optoma W304M, full 3D projector can display true 3D content form any 3D display device, such as 3D Blu-ray, PS3, Xbox and Sky3D.
  • Environmentally friendly
    The X304M incorporates energy saving features to conserve power and extend the lamp life up to 5000 hours. This includes Eco mode, for reduced power consumption during operation, a sleep timer which when activated will automatically switch off the projector if it is accidentally left on when no longer required and a less then 0.5 W standby mode which will ensure the minimum energy consumption when the projector is not being used.
Optoma W304M - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3100 lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
SHP 220 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i
Speakers
Speaker(s) - integrated
280 Watt
22 cm x 17.8 cm x 7.1 cm
1.5 kg
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3100 lumens
Contrast Ratio
10000:1
Image Size
79 cm - 943 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.5 - 1.76:1
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
144 Hz x 91.4 kHz
Bulb type
SHP 220 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
BrilliantColor, 16:9 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, ProJect Green, Amazing Color
Lens
Focus Type
Manual
Lens Aperture
F/2.55-2.72
Zoom Type
Manual
Zoom Factor
1.15x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x USB - 4 pin USB Type B , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
Nominal Voltage
280 Watt
Power Consumption Stand by
0.5 Watt
22 cm
17.8 cm
7.1 cm
1.5 kg
Limited warranty - 2 years , Limited warranty - lamp - 1 year
5 °C
45 °C
0 - 85%
Sound Emission
33 dB
Type: DLP Projector
Brand: Optoma
Price Range Ex VAT: 500 - 750
