Optoma UHD550X 4K UHD Home Cinema Projector
Quicklinx: D0V1WS00 Mfr#: UHD550X
Immerse yourself in Ultra High Definition
  • 4K UHD resolution and HDR compatible
  • Amazing colour - accurate Rec.709 colours, 2800 ANSI lumens
  • Easy connectivity - HDMI 2.0, HDCP 2.2, S/PDIF, 2x 4W speakers
  • Easy installation - vertical lens shift
Immerse yourself in a world of Ultra HD. The UHD550X delivers the ultimate in home entertainment with impressive 4K cinema quality images. TV, gaming and movie fans can now enjoy excellent colour depth, crystal clear detail, and sparkling contrast for a stunningly immersive experience.
Packed with the latest technology and features, the stylish UHD550X boasts High Dynamic Range (HDR) compatibility, HDCP 2.2 support and includes an integrated speaker that provides powerful sound. Bright 2800 lumen images and easy set-up means you can enjoy life-like big-screen entertainment in any living space.
  • 4K UHD resolution
    With over eight million pixels, Ultra HD 4K resolution brings four times more detail than Full HD, to deliver sharper, life-like images and richer colors. Allowing you to sit closer to the screen and enjoy a more immersive experience.
  • HDR compatible
    Capable of receiving and displaying HDR meta data, Optoma HDR compatible projectors allow you to see far more detail and texture. Objects look more solid and life like and the extra detail creates a greater sense of depth. It's like looking through a window.
  • SDR to HDR conversion
    Give your SDR content a second lease of life with SDR to HDR conversion. This unique feature lets you enjoy near-HDR content from any standard source - providing enhanced contrast, detail and colors to all SDR content.
  • Amazing colors
    Watch your movies, TV shows and play games with stunning colors in any environment. Optoma projectors provides you with reliable performance suitable for any content and environment. The home projectors are capable of reproducing the Rec. 709 color gamut, the international HDTV standard to guarantee accurate reproduction of cinematic color exactly as the director intended. Or more saturated colors for a punchy looking image, great for gaming and animated movies.
  • Vertical lens shift
    Simplify installation with vertical lens shift, which provides a wider range of projector placement possibilities. This makes it easier to position the projector in your room and enables a wider range of screen size options.
  • Dynamic Black technology
    This feature gives more depth to your image by smoothly adjusting the lamp output, based on the brightness information of each frame; to create a stunning high contrast ratio. Bright scenes appear crisp and clear, while dark scenes remain detailed with deep blacks and exceptional light and shade detail.
  • UltraDetail
    This technology ensures all the information contained in an image is faithfully reproduced on the screen giving a stunning crystal clear, pin-sharp picture.
  • Color Management System (CMS)
    Display accurate life-like colors to best match your viewing environment. This unique feature provides you with the flexibility to fine-tune the color settings to the Rec. 709 standard for optimal precision.
  • Integrated speaker
    Complete your home entertainment experience with the convenience of a powerful built-in speaker. Built-in speakers provide exceptional sound quality and are easy to set up without the need for costly external speakers.
  • MHL
    Turn your projector into a smart display by connecting a smartphone or tablet with a single cable using MHL to play games, stream videos and share photos on the big screen.
  • USB power
    Use the USB-Power to power an HDMI dongle, such as Google Chromecast.
  • ISF modes
    This feature allows you to save your calibrated day and night mode settings for the highest possible viewing experience.
  • 24p
    Most movies are shot at 24 frames per second (fps). To preserve the purity of the original image, Optoma projectors can accept high definition sources at 24 fps to display movies exactly as the director intended.
  • Gaming mode
    Gaming mode optimizes your projector for lightning response times, maximum contrast and vivid colors to capture every detail - leaving you time to focus on winning.
Optoma UHD550X - DLP projector - LAN
DLP projector - 4K
Built-in Devices
Stereo speakers
Brightness
2800 ANSI lumens
Contrast Ratio
500000:1 (dynamic)
Resolution
3840 x 2160
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Vertical
Bulb type
240 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
Video Input
LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 2160p
Speakers
Speaker(s) - integrated
AC 120/230 V
305 Watt
49.8 cm x 33.1 cm x 14.1 cm
7.8 kg
DLP projector - 4K
Built-in Devices
Stereo speakers
Ethernet
Projector
Brightness
2800 ANSI lumens
Contrast Ratio
500000:1 (dynamic)
Image Size
67 cm - 768 cm
Projection Distance
1.3 m - 9.3 m
Throw Ratio
1.39 - 2.22:1
Uniformity
85 %
Resolution
Ultra HD 4K - 3840 x 2160
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 135 kHz
Bulb type
240 Watt
Bulb life cycle
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Korean
Color Management System, DynamicBlack technology, ISFccc, Game mode, MHL compliance, UltraDetail, High Dynamic Range (HDR)
Lens
Focus Type
Manual
Lens Aperture
F/2.5-3.26
Zoom Type
Manual
Zoom Factor
1.6x
Vertical
Vertical Lens Shift
15%
Video Input
Video Interfaces
VGA, HDMI
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
4 Watt
Speakers
2 x right / left channel
1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB 2.0 - 4 pin USB Type A (management) , 1 x USB - 4 pin USB Type A (power only) , 1 x SPDIF line-out - TOSLINK
Remote control
Security Features
Security lock slot (cable lock sold separately), security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
AC 120/230 V
305 Watt
Power Consumption Stand by
0.5 Watt
49.8 cm
33.1 cm
14.1 cm
7.8 kg
5 °C
10 - 85% (non-condensing)
25 dBA
D0V1 Optoma Beige Ceiling Mount with Pole In Stock £61.71
Resources
The following resources are available for the Optoma UHD550X 4K UHD Home Cinema Projector
