Project bright vibrant presentations effortlessly any time on day. Designed for meeting rooms and classrooms, the S321 boasts sRGB accurate true to life color reproduction, long lamp life and energy-saving features to provide you with a low overall cost of ownership. This projector can be easily connected to a PC or laptop to give you a clear projected image. Portable and lightweight projector can be installed or taken on the move for off-site meetings.
Amazing colors
For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology. This projector also conforms to sRGB standard to produce realistic true to life colors possible. -
Eco+
Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption. -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
3D ready
Optoma 3D ready projectors can output video and images at an astonishing rate of 120 Hz, allowing you to show full screen, full color, stereoscopic 3D; perfect for business and education applications. -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption, further prolonging the life of your lamp. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used.
- Optoma S321 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3200 lumens
- Contrast Ratio
- 22000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 195 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Power
- AC 120/230 V (50/60 Hz)
- 187 Watt
- 29.8 cm x 23 cm x 9.65 cm
- 2.17 kg
- DLP projector
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3200 lumens
- Contrast Ratio
- 22000:1
- Image Size
- 71 cm - 773 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.94 - 2.16:1
- Uniformity
- 75 %
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1920 x 1080 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91.1 kHz
- Bulb type
- 195 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Romanian, Japanese, Korean
- BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, Eco+ technology, ProJect Green
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.4-2.53
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, composite video
- Video Modes
- 1 x USB - mini-USB Type B , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 187 Watt
- Power Consumption Stand by
- 0.5 Watt
- 29.8 cm
- 23 cm
- 9.65 cm
- 2.17 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission
- 29 dB
