Optoma S316 DLP SVGA 3200 Lumens Projector
Quicklinx: 9B3QWS00 Mfr#: S316
Simple to connect to with HDMI connectivity the S316 is ideal for use in a meeting room or classroom. The bright 3200L with 15,000:1 contrast allows you to project bright, crystal clear images with superb colors using DLP, BrilliantColor and Dynamic Eco+ technology.
The S316 also provides you with energy and cost saving features with an incredible lamp life of up to 10,000 hours. It also incorporates a built in speaker, Full 3D technology and optional wireless capabilities allowing you to present wirelessly from a PC or mobile device with ease. Installed or on the move with the included carry bag, the versatile S316 is the perfect projector for all your display needs.
  • Dynamic mode
    Saving energy saves money! Dynamic mode reduces the power consumption to as little as 30%. This intelligent feature can more than double your expected lamp life, lowering the total cost of ownership and reducing maintenance.
  • Brightness where it matters
    Room lighting can be unpredictable for the business traveler; you never know what to expect. The S316 has a powerful lamp producing 3000 ANSI lumens, so you can be sure your presentation will be bright and clear.
  • Eco AV mute
    Stay in control of your presentation with the eco AV mute feature. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also instantly reduces the power consumption to 25%, further prolonging the life of your lamp.
  • Rapid off
    It takes less than 10 seconds for the projector to power up and shutdown, saving both time and energy.
  • Quick resume
    Save time by not waiting for the projector to cool down before it can power up again. If the projector is accidentally turned off, this feature allows the projector to be instantly powered on again, if selected within a period of 100 seconds.
  • Full 3D
    Using the inherent speed of DLP technology, the Optoma S316. Full 3D projector can display true 3D content form any 3D display device, such as 3D Blu-ray, PS3, Xbox and Sky3D.
    Room lighting can be unpredictable for the business traveler; you never know what to expect. The S316 has a powerful lamp producing 3000 ANSI Lumens, so you can be sure your presentation will be bright and clear.
  • Clear, focused images
    Produce a stunning 15,000:1 contrast ratio for pin sharp graphics and crystal clear text using the unique dynamic mode feature.
Optoma S316 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3200 lumens
Contrast Ratio
15000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Speakers
Speaker(s) - integrated
225 Watt
31.46 cm x 22.26 cm x 10.17 cm
2.35 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3200 lumens
Contrast Ratio
15000:1
Image Size
70 cm - 762 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.95 - 2.15:1
Uniformity
80 %
Resolution
SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, AMX Device Discovery, Auto Power Off, On-Screen Help Display, Eco+ technology, ProJect Green
Lens
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x USB - mini-USB Type B (management) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Carrying case, wireless remote control
1 x VGA cable
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
225 Watt
Power Consumption Stand by
0.5 Watt
31.46 cm
22.26 cm
10.17 cm
2.35 kg
5 °C
0 - 85%
29 dB
