Optoma PMG+ - Projection screen 109" (177 cm) 16:10 Matte White
Price Drop! Was £151.66 inc VAT!
Clearance
Price Drop
Last Few Remaining
Quicklinx: BQTJWS00 Mfr#: DS-1109PMG+
Type: Projection screen
£175.93 ex VAT
£211.11 inc VAT
Optoma PMG+ projection screens are popular because they are inexpensive and easy to operate. Optoma manual screens offer several outstanding features.
  • Controlled screen return
    Optoma PMG+ manual screens feature speed reduction-retraction. Simply pull down lightly to release the locking mechanism, let go and the screen will slowly return to the casing.
  • Construction
    The screen fabric consists of a special material that helps prevent the loss of light, making it compatible with virtually every projector. The fabrics are designed to be fire, water, and mold resistant and can be cleaned if required. The outside surface of the matte white screen has microdots that are made with PVC technology. This surface helps with creating the best possible reflection, whilst advances in screen technology help keep the matte white screen flat and retain its shape and effectiveness over longer periods of time.
  • Selflock
    Pull down the screen and hold for 3 seconds, then release. The screen will stay at the desired position.
Optoma PMG+ - projection screen - 109" (277 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Screen Image Diagonal Size
109" (277 cm)
Projection Image Size
234 cm x 146 cm
Aspect Ratio
16:10
Screen Surface
Matte White
16.71 kg
Projection screen
Placing / Mounting
Image Diagonal Size
109" (277 cm)
Image Width
234 cm
Image Height
146 cm
Screen Surface
Matte White
Aspect Ratio
16:10
Gain
1.0x
Border Size
4.7 cm
Extra Border Size
30 cm (top) & 4 cm (bottom)
Black borders
16.71 kg
Mounting Kit
Included
Water-resistant, fire resistant, washable
Brand: Optoma
Price Range Ex VAT: 150 - 300
