Optoma Optoma UHD38x DLP Projector
Quicklinx: HX37WS00 Mfr#: E9PV7GL06EZ3
13 In Stock
£896.98 ex VAT
£1,076.37 inc VAT
The Optoma UHD38x projector is a high-performance digital projector designed to deliver a high-quality viewing experience for both cinema enthusiasts and gamers. With its Ultra HD 4K resolution, images are rendered in stunning clarity and detail, while the 4000 lumens brightness ensures that movies and games look vibrant in any lighting condition. The projector's impressive contrast ratio of 1,000,000:1 ensures deep blacks and bright whites, enhancing the overall picture quality.
Audio is not overlooked, as the integrated 10 W speaker provides a powerful sound output. The Optoma UHD38x is not just about visual quality; it's also designed for convenience and ease of use. With a comprehensive range of connectivity options including HDMI, USB, and audio line-outs, it's easy to connect to a variety of devices. The projector's lamp life is exceptionally long, with up to 15,000 hours in dynamic mode, ensuring that the projector will be a part of your entertainment setup for years to come.
Whether you're watching a blockbuster, streaming a live event, or dominating in a video game, the Optoma UHD38x is engineered to provide an immersive, high-quality experience. Its features like HDR10 compatibility, low input lag, and flexible installation options make it a versatile choice for any home theater or gaming setup.
  • Immersive audio experience
    With an integrated 10 W speaker and mixed channel output, the Optoma UHD38x delivers a clear and powerful audio experience, enhancing any viewing with rich, mono sound.
  • Exceptional brightness and contrast
    Boasting 4000 lumens of brightness and a contrast ratio of 1,000,000:1, this projector produces vibrant, sharp images even in well-lit environments, making it perfect for any time of day.
  • Advanced connectivity options
    Equipped with multiple HDMI ports, audio line-out, SPDIF line-out, USB (power only), and serial RS-232 interfaces, the Optoma UHD38x offers versatile connectivity for a wide range of devices.
  • Designed for gaming and cinema
    Featuring 4-corner correction, 4.2 ms input lag, and HDR10 compatibility, this projector is ideally suited for high-definition video gaming and cinematic experiences, providing stunning visual performance.
  • Long-lasting lamp life
    With a lamp life cycle of up to 15,000 hours in dynamic mode, the Optoma UHD38x ensures extended viewing pleasure with minimal maintenance, making it a cost-effective choice for frequent users.
Optoma UHD38x - DLP projector - 3D
DLP projector - 4K
3D Capable
Yes (3D glasses sold separately)
Brightness
4000 lumens
Contrast Ratio
1000000:1
Resolution
3840 x 2160
Native Aspect Ratio
16:9
Bulb type
240 Watt
Bulb life cycle
Up to 4000 hour(s) - bright mode , Up to 10000 hour(s) - economic mode , Up to 15000 hour(s) - dynamic mode
Video Modes
480i, 480p, 576i, 576p, 720/50p, 720/60p, 1080/50i, 1080/60i, 1080/50p, 1080/60p, 2160/50p, 2160/60p, 1080/24p
Speakers
Speaker(s) - integrated
AC 100-240 V (50/60 Hz)
31.5 cm x 27 cm x 11.8 cm
3.98 kg
DLP projector - 4K
3D Capable
Projector
Brightness
4000 lumens
Contrast Ratio
1000000:1
Image Size
84 cm - 762 cm
Projection Distance
1.21 m - 9.9 m
Throw Ratio
1.5 - 1.66:1
Uniformity
80 %
Resolution
Ultra HD 4K - 3840 x 2160
Native Aspect Ratio
16:9
Max Sync Rate (V x H)
120 Hz x 135 kHz
Bulb type
240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
English, French, German, Italian, Japanese, Portuguese, Russian, Chinese (simplified), Spanish
4:3 aspect ratio support, 4.2ms input lag, Hybrid Log-Gamma (HLG), High Dynamic Range (HDR), Amazing Color, Colour Management System (CMS), ISF modes, Game mode, wall colour correction, 4 Corner Correction, HDR10 compatibility, Rec. 709 Mode
Lens
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical, horizontal
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-40 / +40
Video Input
Video Interfaces
HDMI
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm , 1 x SPDIF line-out , 1 x USB (power only) - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x 12V programmable trigger
Backlit remote control, 2 x AAA batteries
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
Power Source
AC
Power Consumption Stand by
0.5 Watt
31.5 cm
27 cm
11.8 cm
3.98 kg
Shipping Weight
4.68 kg
5 °C
85%
Sound Emission
26 dB
Brand: Optoma
Price Range Ex VAT: £750 - £1000
