Optoma NuForce BE6i Bluetooth Earphones with Microphone - Grey
Quicklinx: CKSQWS00 Mfr#: H1MB22129295
Accessory Type: Earphones
Connectivity: Wireless
Colour: Grey
Colours:
£84.48 ex VAT
£101.37 inc VAT
The BE6i is the next evolution of the award-winning BE6 - which achieved numerous awards and accolades, including a 'Recommended' award from techradar.com, 4 stars from The Daily Mirror and GadgetSpeak.com. Digitaltrends.com also featured the BE6 in their list of the '10 best Bluetooth headphones'.
The BE6i takes the same stylish design as the BE6 but offers an incredible battery life of up to 8 hours. They are also IPX5 certified for greater protection from rain and sweat. The BE6i are the only Bluetooth® in-ear headphones to be fully crafted from aluminium, which provides crystal-clear sound and elegant design in a lightweight form-factor, making them durable and attractive for all lifestyles. In addition, the headphones feature Bluetooth with aptX® and AAC compatibility, for the ultimate quality in audio streaming.
Ultimate sound quality
Featuring Bluetooth with AAC and aptX® compatibility for iPhone®, Android™ and Windows®
More listening time
Incredible battery life of up to 8 hours
Ultra-lightweight solid metal casing
Better sounding, tougher, water-resistant (IPX5 certified)
Rock solid wireless performance
Cordless experience with exceptional 30 metre Bluetooth® range
Superior sound on the go
aptX® - the BE6i are compatible with aptX, which allows users to listen to CD-quality music wirelessly in much higher quality than offered from the standard Bluetooth codec. aptX is supported by the latest Android, Apple and Windows smartphones, Macs and PCs.
AAC - BE6i in-ear headphones support AAC, which provides the best listening experience when playing music from Apple devices and a variety of other sources such as YouTube, DAB radio and streaming services.
Non-stop music and calls
The BE6i can play music and take phone calls continuously for up to eight hours and are equipped with an in-line remote control that can skip tracks, engage Siri or Google Voice and activate Bluetooth pairing mode. And with a 30 metre range you can even leave your phone or tablet on the floor whilst you focus on your workout.
IPX5 water-resistant
With a rating of IPX5, the BE6i in-ear headphones are weather resistant, ensuring protection from rain and sweat - making them ideal for any active lifestyle.
Freedom to move
For ultimate comfort and a secure fit during outdoor activities or sports, a wrap-around neckband, clip and silicone ear wings are included with the BE6i. Bluetooth® means you won't need to worry about wires getting in the way as you move.
Comfortable fit
Proprietary NuForce silicone ear tips - five sets of custom designed silicone ear tips are included with the BE6i in-ear headphones. Three sets are slightly shorter than average ear tips offering greater comfort when used for prolonged periods. The other three sets are longer - designed for improved noise isolation and a secure fit for an active lifestyle.
Comply™ soft foam ear tips - two sets of heat activated memory foam ear tips are included. They expand to fit the ear canal for a secure fit and improved noise isolation. Replacement Comply tips are available for purchase online. Users should look for the Comply 500 series variants.
Newly developed and patented 10mm driver
This large driver eliminates unwanted reverberations for distortion-free sound even at high volume levels.
Elegant styling
Available in grey and gold, the BE6i in-ear headphones are matched with Apple and other leading smart devices.
What's in the box?
  • A pair of BE6i earphones
  • 4 x pairs proprietary NuForce silicone
  • earbuds (XS, S, M, L)
  • 2 x pairs Comply foam earbuds (M, L)
  • 1 x pair ear hooks
  • 1 x USB charging cable (USB A-USB micro)
  • 1 x carry case
  • 1 x cable management clip
  • User guide
  • Non-stop music and calls
    The splash-proof earphones continuously play music and take phone calls for a few hours and are equipped with an in-line remote control, that can skip tracks, and activate Bluetooth pairing mode. And with a wide range you can even leave your phone or tablet on the floor whilst you focus on your workout.
  • Freedom to move
    Bluetooth means you won't need to worry about wires getting in the way as you move.
  • Improved driver
NuForce BE6i - earphones with mic
Earphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod, Android phone, Windows phone
Recommended Use
Portable electronics
Grey
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 95 dB
Impedance
20 Ohm
Microphone
On-cable
Controls
Volume control, answer/end
Compatibility
19.8 g
Grey
Recommended Use
Protection
Waterproof, sweat-resistant
Max Operating Distance
30 m
Headphones
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
95 dB
Impedance
20 Ohm
Diaphragm
10 mm
In-Cord Volume Control
Microphone
On-cable
Remote Control
Controls
Wireless Link
Transmission Range
30 m
Cable
Cable Length
56.1 cm
Carrying case, 4 pairs of ear tips, 2 earhooks, cable clip, 2 pairs of Comply foam ear tips
Cable Details
USB charge cable
Headphone battery rechargeable - Lithium Ion
80 mAh
Run Time (Up To)
8 hours
Colour: Grey
Brand: Optoma
Price Range Ex VAT: 50 - 100
