Wireless Bluetooth in-ear headphones for sports
Stay motivated when you're pushing yourself to the limits with the BE Sport4 Bluetooth in-ear headphones. The lightweight, durable design and custom ear tips keep them securely in place no matter how vigorous your workout – without the distraction of wires. In addition, wireless means a future fit to smartphones that don’t include an audio jack.
Sweat and water resistant - IPX5
Resistant against rain and sweat, these IPX5 in-ear headphones are ideal for any active lifestyle.
Wireless Freedom
Free yourself from cables with advanced Bluetooth® technology. This means easy connection to your smartphone and distortion-free listening at any volume. And with a 10 metre (33ft) range you can even leave your smartphone on the floor or in your pocket whilst you focus on your workout.
Graphene coated drivers
Compared to traditional drivers, graphene coated drivers are lighter, more precise and have excellent conductivity which requires less power to drive. This means that no matter what genre of music you are listening to, the bass, mids and high tones are clearly defined with low distortion.
aptX
Supported by the latest Android and Windows smartphones and PCs, aptX allows you to listen to CD-quality music wirelessly in much higher quality than offered from the standard Bluetooth codec.
AAC
Hear every detail when playing music from Apple devices and other sources such as YouTube, DAB radio and streaming services.
Quick Charge
Enjoy up to two hours of continuous listening with a 15 minute charge.
Non-stop music and calls
Enjoy continuous uninterrupted audio and phone calls throughout the day on a single charge with an impressive battery life.
Maximum comfort and perfect fit
With stylish and robust enclosures, these ergonomically designed earbuds feature an angled nozzle, a built in magnet, wrap-around neckband and come with multiple ear tips in a range sizes to ensure a comfortable and secure fit.
SpinFit TwinBlade® ear tips
The newly patented ear tips are developed from high quality silicone. They are uniquely designed with twin blades to keep the earbuds securely in place during strenuous activity. As well as being able to rotate 360 degrees at the centre to allow the earbuds to sit comfortably in your ear.
Wings tips
Supplied with specially designed wing tips to lock the earbuds in securely in your ear and stop them falling out during strenuous activity.
In line remote with built in mic
Equipped with an in-line remote control with a built in mic, you can adjust the volume, play, pause and switch tracks, activate Siri or Google Voice and answer calls
