Optoma ML750ST 1280 x 800 HDMI VGA 3D Projector
Quicklinx: BXT4WS00 Mfr#: 95.71Z01GC0E
The addition to Optoma's ultra-portable LED projector range, ML750ST, builds upon the popular ML750e. Weighing just 420g, it has all the same features as the tiny ML750e, but has been engineered with a short throw lens to make it even more flexible in meetings.
Short throw
With a short throw lens, you can project a striking 100" image from a little over a metre away. This lets you to put the projector closer to the wall, reducing shadows so you can present with ease.
LED technology
Optoma LED projectors use individual red, green and blue LED modules to create the projected image without the need for a colour wheel. LED illumination provides consistent brightness and colour performance with increased efficiency to maintain its out-of-the-box image quality. And the extraordinary life of LEDs (up to 20,000 hours) will ensure it stays clear and bright. In many circumstances the perceived brightness of LED projectors can be up to twice the brightness of an equivalent lamp-based projector. LED brightness* specifications allow for a better comparison against lamp-based projectors, which do not take advantage of the enhanced brightness perception the Helmholtz-Kohlrausch (HK) effect creates.
Bright, vibrant images - Rec709
Ideal for business presentations, watching movies or displaying graphics, the LED powered ML750ST delivers a wide colour gamut, superior colour saturation and outstanding brightness to produce intense yet accurate colours, achieving the Rec709 standard.
LED auto calibration
This small projector has a built in sensor that auto calibrates the LEDs every time the projector is switched on. This provides you with reliable colour performance and maintains the projectors out-of-the-box image quality throughout its lifetime and saving you from costly calibrations.
MHL
Turn your projector into a smart display by connecting your smartphone or tablet with a single cable using MHL*; now you can view presentations and documents, stream videos and share photos on the big screen. *Connection to some devices may require additional cables and adapters, available separately.
360° projection
Images can be projected vertically over a full 360° range, plus reproduction onto a ceiling or floor.
Digital signage
Digital signage applications are ideal as the projector can be mounted in virtually any orientation and it can automatically play video files or a photo slideshow directly from a microSD card as soon as the projector is switched on. You can even set the projector to turn off after a set period of time using the 'sleep timer' function.
Instant on/off
With instant power on/off LED technology, the ML750ST is primed for instant plug-and-play viewing on the move.
Media player and native office viewer
Give presentations and view Microsoft Office and Adobe PDF files directly from your projector, without the need of a laptop or PC using the built-in media player. Simply copy your documents, images or videos to a microSD card, USB memory stick or the internal memory and display them on the big screen.* *Microsoft Office powerpoint animations are not supported. For a full list of supported files types please download the user manual. microSD card and USB memory stick not included. Supports SDHC up to 64GB.
Auto keystone
Auto keystone correction helps ensure that the projected image will always fit the area on which you are projecting.v
Optoma ML750ST - DLP projector - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
800 lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB
Supported Memory Cards
microSD, microSDHC
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
77 Watt
11.25 cm x 12.3 cm x 5.7 cm
420 g
3D Capable
Built-in Devices
Speaker
Enclosure Colour
Projector
Microdisplay
DMD Chip
Brightness
800 lumens
Contrast Ratio
20000:1
Image Size
63 cm - 508 cm
Projection Distance
0.43 m - 3.44 m
Throw Ratio
0.8:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 49.64 kHz
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
OSD Languages
Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Greek, Turkish
BrilliantColor, 16:9 aspect ratio support, 4:3 aspect ratio support, MHL compliance, built-in 1.5 GB flash memory, integrated media player
Lens
Lens Aperture
F/1.9
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
Video Modes
microSD, microSDHC
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1.5 Watt
Speakers
1 x mixed channel
Expansion Slots
1 x microSDHC
1 x USB - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA input - 15 pin HD D-Sub (HD-15) (on supplied cable) , 1 x headphones - mini-phone stereo 3.5 mm
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
RoHS
Nominal Voltage
77 Watt
Power Consumption Stand by
0.5 Watt
11.25 cm
12.3 cm
5.7 cm
420 g
5 °C
35 °C
10 - 85% (non-condensing)
22 dB
BXT4 C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
BXT4 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.14
BXT4 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.11
BXT4 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.19
BXT4 C2G USB Superbooster Extender Kit In Stock £38.85
