Optoma ML750e WXGA LED Projector 700 Lumens HDMI  Built in Speaker
Installation required? Contact us today!
Quicklinx: B9F1WS00 Mfr#: ML750e
Brightness: 700ANSI lumens
Portability: Pocket
£391.11 ex VAT
£469.33 inc VAT
Introducing the all new ML750e ultra-compact portable LED projector. Easily transportable between your home and office, this tiny projector weights incredibly light and comes with a convenient carry bag. Watch HD movies, play video games or even present that winning presentation, the ML750e has everything you need to impress your audience.
Packed full of features the ML750e incorporates a media player, native office viewer and built-in speaker. Project without a laptop using the built-in memory, a microSD card slot, USB connection. Easily connect and display from a mobile or table device using MHL connectivity to play a game on a big screen, view business files, photos, videos or to just listen to music.
Using the latest "Lamp-free" technology for exceptional color fidelity, reliability and longevity, the Optoma LED ultra - compact portable projector is your perfect entertainment and business partner.
  • Ultra compact
    Weighing less than 0.4kg, the ML750e is ultra light and compact. Coupled with the included carry case make it ideal for presentations on the go.
  • Media player and native Office Viewer
    Play videos, photos, Microsoft Office & Adobe PDF files directly from the internal memory, a microSD card or USB stick and view them directly on the projector without the need to connect the projector to a laptop, PC or DVD player.
  • Videos
    Sit back after a long day to enjoy your favorite movies... The ML750e directly supports the most popular video and music file formats and being both HD-Ready and LED, you can also be sure of vibrant colors, depth, and clarity that will not disappoint.
  • Wireless presentations
    Present from your phone or tablet using the free App: EZ View. Available for both Android and iOS devices, EZ View gives you the freedom to wirelessly share and present documents, photos, videos and your devices camera turning it into a document camera. Creating a more connected and collaborative experience for everyone. Instantly connect and display presentation material wirelessly from a PC, Mac or mobile device using the optional mini WiFi dongle which connects discreetly to the USB port on your ML750e, bringing you seamless wireless connectivity in a highly portable package. Enjoy big-screen presentations streamed to your projector, cable-free.
  • Easy connectivity - MHL
    Easily connect to a laptop, PC, games console or DVD player with HDMI. The ML750e is also MHL compatible, this allows you to connect your MHL enabled mobile device with a single cable solution† allowing you to mirror your devices screen. Ideal for streaming movies and viewing files and photos stored on your mobile device.
  • 3D ready
    Using the inherent speed of DLP technology, Optoma 3D Ready projectors can output video and images at an astonishing rate of 120Hz, allowing you to show full screen, full color, stereoscopic 3D. Useful for both professionals and educators alike, the ML750e brings both teaching and design to a whole new level of immersion and excitement. Useful for both professionals and educators alike, the ML750e brings both teaching and design to a whole new level of immersion and excitement.
Optoma ML750e - DLP projector - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
700 lumens
Contrast Ratio
15000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s) - economic mode
Video Input
RGB
Supported Memory Cards
microSD
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
65 Watt
10.5 cm x 10.6 cm x 3.9 cm
380 g
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DMD Chip
Brightness
700 lumens
Contrast Ratio
15000:1
Image Size
43 cm - 254 cm
Projection Distance
0.55 m - 3.23 m
Throw Ratio
1.5:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 49.64 kHz
Bulb type
LED
Bulb life cycle
Controls & Adjustments
Keystone correction
High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, MHL compliance, built-in 1.5 GB flash memory
Lens
Lens Aperture
F/2.0
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
Video Modes
microSD
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Expansion Slots
1 x microSD
1 x USB - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA input - 15 pin HD D-Sub (HD-15) (on supplied cable) , 1 x audio line-out - mini-phone stereo 3.5 mm (on supplied cable)
Carrying case, wireless remote control
1 x VGA / audio cable
Security Features
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
Nominal Voltage
65 Watt
Power Consumption Stand by
0.5 Watt
10.5 cm
10.6 cm
3.9 cm
380 g
5 °C
35 °C
0 - 85%
30 dB
Portability: Pocket
Brand: Optoma
Price Range Ex VAT: 300 - 500
