Introducing the all new ML750e ultra-compact portable LED projector. Easily transportable between your home and office, this tiny projector weights incredibly light and comes with a convenient carry bag. Watch HD movies, play video games or even present that winning presentation, the ML750e has everything you need to impress your audience.
Packed full of features the ML750e incorporates a media player, native office viewer and built-in speaker. Project without a laptop using the built-in memory, a microSD card slot, USB connection. Easily connect and display from a mobile or table device using MHL connectivity to play a game on a big screen, view business files, photos, videos or to just listen to music.
Using the latest "Lamp-free" technology for exceptional color fidelity, reliability and longevity, the Optoma LED ultra - compact portable projector is your perfect entertainment and business partner.
- Optoma ML750e - DLP projector - 3D
- DLP projector - High Definition 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DMD Chip
- Brightness
- 700 lumens
- Contrast Ratio
- 15000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Bulb type
- LED
- Bulb life cycle
- Up to 20000 hour(s) (economic mode)
- Video Input
- RGB
- Supported Memory Cards
- microSD
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 65 Watt
- 10.5 cm x 10.6 cm x 3.9 cm
- 380 g
- 2 years warranty
- DLP projector - HD 720p
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DMD Chip
- Brightness
- 700 lumens
- Contrast Ratio
- 15000:1
- Image Size
- 43 cm - 254 cm
- Projection Distance
- 0.55 m - 3.23 m
- Throw Ratio
- 1.5:1
- Uniformity
- 85 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 49.64 kHz
- Bulb type
- LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, MHL compliance, built-in 1.5 GB flash memory
Lens
- Lens Aperture
- F/2.0
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI
- Video Modes
- microSD
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- Expansion Slots
- 1 x microSD
- 1 x USB - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA input - 15 pin HD D-Sub (HD-15) (on supplied cable) , 1 x audio line-out - mini-phone stereo 3.5 mm (on supplied cable)
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA / audio cable
- Security Features
- RoHS
- Power Source
- AC
- Nominal Voltage
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- 10.5 cm
- 10.6 cm
- 3.9 cm
- 380 g
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 30 dB
