Insert the SD card straight from your phone or camera to instantly share memories with small or large groups, without the need for extra cables. Alternatively leave a slideshow with audio running in the background before kicking off a meeting, to whet your audiences' appetite and stimulate discussion. Sit back after a long day to enjoy your favorite movies... without the need for file conversion; the ML1500 directly supports all the most popular video and music file formats and being both HD-Ready and LED, you can also be sure of vibrant colors, depth and clarity that will not disappoint.
Photos
Insert the SD card straight from your phone or camera to instantly share memories with small or large groups, without the need for extra cables. Alternatively leave a slideshow with audio running in the background before kicking off a meeting, to whet your audiences' appetite and stimulate discussion. -
Videos
Sit back after a long day to enjoy your favorite movies... without the need for file conversion; the ML1500 directly supports all the most popular video and music file formats and being both HD-Ready and LED, you can also be sure of vibrant colors, depth and clarity that will not disappoint. -
Presentation and documents
With native support for Microsoft Office and Adobe PDF files, you can simply save your work onto an SD card or USB memory stick and you are ready to go. -
Media player and native office viewer
Play videos, photos, Microsoft Office and Adobe PDF files directly from an SD card or USB stick and view them directly on the projector without the need to connect the projector to a laptop, PC or DVD player. -
Wireless presentations
Present from your phone or tablet using the free application: Wi-Fi-Doc. Available for both Android and iOS devices, Wi-Fi-Doc gives you the freedom to wirelessly share and present documents and photos stored on your mobile device. Creating a more connected and collaborative experience for everyone. -
LED technology
Powered by LED's, the ML1500 delivers a wide color gamut, superior color saturation and outstanding brightness using separate Red, Blue and Green LEDs to produce intense yet accurate colors.
- Optoma ML1500e - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 1500 lumens
- Contrast Ratio
- 20000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- Composite video (NTSC, PAL, M-NTSC)
- Supported Memory Cards
- SD Memory Card
- Video Modes
- 480p, 720p, 1080i, 480i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 145 Watt
- 27 cm x 17 cm x 4.8 cm
- 1.4 kg
- 2-year warranty
- 3D Capable
Projector
- Brightness
- 1500 lumens
- Contrast Ratio
- 20000:1
- Image Size
- 43 cm - 254 cm
- Projection Distance
- 0.52 m - 3 m
- Throw Ratio
- 1.4:1
- Uniformity
- 85 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 49.64 kHz
- Bulb type
- LED
- Bulb life cycle
- OSD Languages
- Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Greek, Turkish
- BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, ProJect Green, SRS WOW HD technology
Lens
- Lens Aperture
- F/1.5
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, PAL, M-NTSC
- Analogue video Signal
- Composite video
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- SD Memory Card
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 3 Watt
- Expansion Slots
- 1 x SD Memory Card
- 1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 2 x USB - 4 pin USB Type A , 1 x USB - 5 pin Micro-USB Type B
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x HDMI cable
- Security Features
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 145 Watt
- Power Consumption Stand by
- 0.5 Watt
- 27 cm
- 17 cm
- 4.8 cm
- 1.4 kg
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 30 dB
