Optoma ML1500e WXGA 1280 x 800 HDMI VGA Portable 3D Projector
Quicklinx: BXSTWS00 Mfr#: ML1500e
Insert the SD card straight from your phone or camera to instantly share memories with small or large groups, without the need for extra cables. Alternatively leave a slideshow with audio running in the background before kicking off a meeting, to whet your audiences' appetite and stimulate discussion. Sit back after a long day to enjoy your favorite movies... without the need for file conversion; the ML1500 directly supports all the most popular video and music file formats and being both HD-Ready and LED, you can also be sure of vibrant colors, depth and clarity that will not disappoint.
  • Photos
  • Videos
  • Presentation and documents
    With native support for Microsoft Office and Adobe PDF files, you can simply save your work onto an SD card or USB memory stick and you are ready to go.
  • Media player and native office viewer
    Play videos, photos, Microsoft Office and Adobe PDF files directly from an SD card or USB stick and view them directly on the projector without the need to connect the projector to a laptop, PC or DVD player.
  • Wireless presentations
    Present from your phone or tablet using the free application: Wi-Fi-Doc. Available for both Android and iOS devices, Wi-Fi-Doc gives you the freedom to wirelessly share and present documents and photos stored on your mobile device. Creating a more connected and collaborative experience for everyone.
  • LED technology
    Powered by LED's, the ML1500 delivers a wide color gamut, superior color saturation and outstanding brightness using separate Red, Blue and Green LEDs to produce intense yet accurate colors.
Optoma ML1500e - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Brightness
1500 lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
Composite video (NTSC, PAL, M-NTSC)
Supported Memory Cards
SD Memory Card
Video Modes
480p, 720p, 1080i, 480i, 576p
Speakers
Speaker(s) - integrated
145 Watt
27 cm x 17 cm x 4.8 cm
1.4 kg
3D Capable
Projector
Brightness
1500 lumens
Contrast Ratio
20000:1
Image Size
43 cm - 254 cm
Projection Distance
0.52 m - 3 m
Throw Ratio
1.4:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 49.64 kHz
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
OSD Languages
Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Greek, Turkish
BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, ProJect Green, SRS WOW HD technology
Lens
Lens Aperture
F/1.5
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, PAL, M-NTSC
Analogue video Signal
Composite video
Video Interfaces
VGA, HDMI, composite video
Video Modes
SD Memory Card
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Expansion Slots
1 x SD Memory Card
1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 2 x USB - 4 pin USB Type A , 1 x USB - 5 pin Micro-USB Type B
Carrying case, remote control
1 x HDMI cable
Security Features
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
145 Watt
Power Consumption Stand by
0.5 Watt
27 cm
17 cm
4.8 cm
1.4 kg
5 °C
35 °C
0 - 85%
30 dB
