Your basket is empty
Optoma ML1500e WXGA 1280 x 800 HDMI VGA Portable 3D Projector
Quicklinx: BXSTWS00 Mfr#: ML1500e
Insert the SD card straight from your phone or camera to instantly share memories with small or large groups, without the need for extra cables. Alternatively leave a slideshow with audio running in the background before kicking off a meeting, to whet your audiences' appetite and stimulate discussion. Sit back after a long day to enjoy your favorite movies... without the need for file conversion; the ML1500 directly supports all the most popular video and music file formats and being both HD-Ready and LED, you can also be sure of vibrant colors, depth and clarity that will not disappoint.
Optoma ML1500e DLP projector - 3D
DLP projector - High Definition 720p
3D Capable
Yes (3D glasses sold separately)
Brightness
1500 lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
Composite video (NTSC, PAL, M-NTSC)
Supported Memory Cards
SD Memory Card
Video Modes
480p, 720p, 1080i, 480i, 576p
Speakers
Speaker(s) - integrated
145 Watt
27 cm x 17 cm x 4.8 cm
1.4 kg
2 years warranty
DLP projector - HD 720p
3D Capable
Projector
Brightness
1500 lumens
Contrast Ratio
20000:1
Image Size
43 cm - 254 cm
Projection Distance
0.52 m - 3 m
Throw Ratio
1.4:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 49.64 kHz
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
OSD Languages
Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Greek, Turkish
BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, ProJect Green, SRS WOW HD technology
Lens
Lens Aperture
F/1.5
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, PAL, M-NTSC
Analogue video Signal
Composite video
Video Interfaces
VGA, HDMI, composite video
Video Modes
SD Memory Card
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Expansion Slots
1 x SD Memory Card
1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 2 x USB - 4 pin USB Type A , 1 x USB - 5 pin Micro-USB Type B
Carrying case, remote control
1 x HDMI cable
Security Features
RoHS
Power Source
AC
Nominal Voltage
145 Watt
Power Consumption Stand by
0.5 Watt
27 cm
17 cm
4.8 cm
1.4 kg
5 °C
35 °C
0 - 85%
30 dB
