Optoma HD200X Full HD Home Cinema Projector
Quicklinx: 62GZWS00 Mfr#: so
  • High-Definition Multimedia Interface (HDMI)
The HD200X home cinema projector delivers the kind of picture quality associated with the best digital cinema performance around the world. With a digital HDMI signal you can create a true digital projection system that produces a spectacular Full HD cinematic experience in your own home. A masterly collaboration of Full HD DLP technology from Texas instruments and Optoma craftsmanship produces a stunningly bright image with perfectly balanced vivid color, crystal clarity and the exceptional light and shade detail only possible with a high ANSI contrast projector.
  • ANSI contrast
    ANSI contrast is a way of measuring the true "real world" contrast performance you can expect from a projector in your own home. This measurement technique includes a reproducible procedure that can be used to compare the performance of projectors using different display technologies. With an ANSI contrast ratio significantly higher than many LCD based projectors, the HD2000X is the only choice for Home Cinema purists that expect ultimate image fidelity in their home.
  • 24P
    Most movies are shot at 24 frames per second. To preserve the purity of the original image the HD200X can accept High Definition sources at 24 frames per second and so to display movies exactly as the director intended.
Optoma HD200X - DLP projector - portable
DLP projector - 1080p
Brightness
1500 lumens
Contrast Ratio
3500:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
230 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL)
Digital Video Standard
Video Modes
480p, 720p, 1080i, 1080p, 480i
308 Watt
32.4 cm x 23.4 cm x 9.7 cm
2.9 kg
Projector
Brightness
1500 lumens
Contrast Ratio
3500:1
Image Size
95 cm - 764 cm
Projection Distance
1.5 m - 10 m
Throw Ratio
1.5 - 1.8:1
Resolution
Native Aspect Ratio
16:9
Colour Support
Bulb type
230 Watt
Bulb life cycle
Lens
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-5/ +5
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Input Device
External
2 x HDMI input - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA
Wireless remote control
308 Watt
Power Consumption Operational (Standby)
1 Watt
32.4 cm
23.4 cm
9.7 cm
2.9 kg
5 °C
35 °C
0 - 80%
Sound Emission
34 dB
