Project high resolution visuals regardless of the ambient light level using the bright full HD 1080p EH416. Designed for businesses and professional installation environments this compact and powerful projector can be installed or taken on the move. Perfect for small edge blending and stacking projects.
Large zoom range
A large zoom range enables multiple placement possibilities at a variety of distances from the projection screen. An advantage to this is that expensive interchangeable lens projectors can be substituted with a more cost effective solution whilst still retaining a diverse choice of positioning options. -
Eco+
Eco+ Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption. -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used -
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images. -
Long lamp life
Reduce the number of lamp changes with lamp life of long hours. -
Vertical lens shift
Simplify installation with vertical lens shift, which provides a wider range of projector placement possibilities. This makes it easier to position the projector in your room and enables a wider range of screen size options. -
USB power
Use the USB-Power to power an HDMI dongle, such as Google Chromecast. -
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off. -
Remote mouse and laser
Keep your audience's attention focussed on the right things using the simple, yet powerful remote with USB mouse control and built in laser pointer -
Networking and control
Featuring a wide range of options you can remotely control and monitor the projector.
- Optoma EH416 - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 4200 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Vertical
- Bulb type
- 260 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 309 Watt
- 31.4 cm x 22.4 cm x 11.4 cm
- 2.99 kg
- 3D Capable
- Networking
- Ethernet
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 4200 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 67 cm - 770 cm
- Projection Distance
- 1.3 m - 9.4 m
- Throw Ratio
- 1.4 - 2.24:1
- Uniformity
- 75 %
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- 260 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- BrilliantColor, 16:9 aspect ratio support, PJlink, Crestron RoomView, 16:10 aspect ratio support, 4:3 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology, ProJect Green, MHL compliance
Lens
- Lens Aperture
- F/2.5-3.26
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
- Vertical
- Vertical Lens Shift
- 15%
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- HDMI, component video, composite video, RGB
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x HDMI - 19 pin HDMI Type A , 1 x management - mini-USB Type B , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB (power only) - 4 pin USB Type A (power only)
- Included Accessories
- 2 x AAA batteries, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 309 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.4 cm
- 22.4 cm
- 11.4 cm
- 2.99 kg
- 5 °C
- 40 °C
- 10 - 85% (non-condensing)
- Sound Emission (Economic Mode)
- 32 dB
